Just bought a new to us Coachmen Apex Nano 213. I figured I would flush the fresh water tank. So after filling it with bleach and water mixture, I ran the faucets and I noticed that the water pump pulsates with a single tap on and not with two on. Is this normal? I tried turning the adjustment screw as seen on youtube but it didn't change. It's a surflo 4008 pump. Does anyone have any experience with this type of thing?
If this happens on both hot and cold there could easily be construction debris in the faucet(s). If only one line there's possible kinks in the plumbing.
-- Chuck
I think what you have is normal. With one faucet open the pump pumps water faster the the one faucet passes so it pulses. With two open water flow from both are what the pump pumps so it keeps running. My pump reacts just like yours.
There is a pressure setting screw on the water pump you can adjust to help with the problem. I've just left my alone, though, and it acts exactly the same way. Perfectly normal, but the screw adjustment can help.
Normal pump operation. If you want to minimize the pump switching on and off at low flow rates, you can install an accumulator tank. The accumulator would reduce pump cycling.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
