Forgive me as I can not find this in the search. I am a new owner, and new to rvs in general.
I switched sites recently, as normal hooked everything up to city water as normal and now my fresh water is overflowing and it has never done that and is always 1/3 full. I use it for washing and toilet when traveling. Now I am not sure what to do to fix this. I had a search online with no results as well.
Try this.
Disconnect city water.
Make sure water pump is off
Open faucet and Run water until it stops
Close faucet and trun on water pump until it stops
Run water for 30 seconds and turn off
Once water pump stops, turn off water pump
Reconnect to city water.
This will reseat the back flow valve in the pump. You should not run water pump when connected to city water.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
senanic, it would help us, help you, if you either posted year/make/model of RV or put that info in your profile.
