Originally Posted by Bear fans
It's a 2019, still under warranty? My fix would be for the dealer to repair it while it's under warranty and so it's documented in case it becomes a recurring issue.
Too easy to hassle with taking it in.
Originally Posted by chaps2018
I had the same issue Lon the same side but can’t recall how I resolved it. Seems like I was able to extend the length by removing the screw at the bottom then reinstalled it.
To answer your question. The material is similar to this. Just need to match the width and color. Autmotive Authority Black Vinyl 1" Insert Molding Trim Screw Cover RV Camper Travel Trailer (Black, 35 ft) https://www.amazon.com/dp/B077H2WT94..._0DZvEb9VWW0CH
Don't see a screw anywhere on mine, but good thought. Did pick up the item you suggested - looks like it should work no problems.
Originally Posted by KSH
Awesome thanks, didn't know where to start looking for this.
Originally Posted by 5er_tom
Had that issue on my Wildcat. I waited for a hot day, stretched it, applied Goop glue and duct taped it overnight. No issue for 2 years now.
Wish I had the warmer weather!!!
