05-28-2018, 09:04 PM
#21
Originally Posted by Kchamp40
My issue is the hard lines under wallpaper looking like termite tracks. The texture is gritty but you can’t wipe or scrape it off. Today we hit on wall and husband put a small razor in wall and wood has black blotches on it then tiny bugs, size of a flea but have ant body, appeared from no where. Leak causing bugs? Or bugs causing damage? We are not sure. Dealership cannot see us for 2 weeks and I’m worried serious damage is happening
Here's info on powder post beetles. They don't look like the pic you posted, so hopefully that's a good thing.
https://www.doyourownpestcontrol.com...ostbeetles.htm
2011 Traverse LT, 3.6L, FWD
05-28-2018, 09:22 PM
#22
Looks like a carpenter ant to me. Is it red or black? In Florida they are red.
05-28-2018, 09:49 PM
#23
Originally Posted by rockfordroo
Thanks! I’ve learned it is definite an ant. I know Forest River had issues with that beetle even saw someone in their forum ended their discussion per a non disclosure settlement [emoji848]
Frank & Katie
New Orleans, LA
"The Note" a 2018 Forester DS3011
05-28-2018, 09:51 PM
#24
Black and the size of a flea. We only see them if we hit on the wall and just 3 or 4 at a time
Frank & Katie
New Orleans, LA
05-28-2018, 09:55 PM
#25
Not a carpenter ant, too small, but an ant just the same.
05-28-2018, 10:00 PM
#26
True. Visual damage is one thing it’s what we don’t see that has me worried and RV is only year old and I doubt anything will be covered by warranty.
Frank & Katie
New Orleans, LA
05-28-2018, 10:03 PM
#27
Has anyone seen anything like this? The wallpaper design makes it hard to see and you can only see in certain light. This is located on the rear wall of RV. It looks grainy like sand and is tough but you can’t remove it. It’s hard and behind wallpaper. Thanks!
Katie & Frank
2018 Forester “The Note”
Attachment 173738Attachment 173739
If we cut a hole in wall to see if we can determine damage do you think that would void any warranty? Or if i get an exterminator?
Frank & Katie
New Orleans, LA
05-28-2018, 10:09 PM
#28
Termites or Carpenter Ants? What to Look Out For : Steve Allen Construction
This link has useful info to help identify carpenter ants or termites. Not a great photo but I am leaning towards carpenter ants. Definitely call an exterminator right away. Do you see any ants around your tires, power cord, jacks or stabilizers? Termites like moist wood not sure about carpenter ants. Still check inspect roof and walls for leaks.
Michael & Fran Dilday (Baxter & Honey 2 Labs)
'18 Cedar Creek Champagne 38EL - '17 Ford F350 Lariat DRW w/Reese hitch - TST 507 Color TPMS - Garmin RV 770 LMT GPS
05-28-2018, 10:14 PM
#29
Thank you. I’ll call exterminator to identify and treat and just wait for my dealership appointment to assess damage and find out if there may be a leak.
Frank & Katie
New Orleans, LA
05-29-2018, 07:55 AM
#30
Ive had problems with ants at my house. This works well for me.
1 1/2 cups water
1/2 cup icing sugar
1 1/2 tbsp borax or borasic acid.
Put a small amount in something like a small margarine container. Also use a cotton ball or gauze pad to wick the solution up to the side of your container. Place at the ants location. Ants will be attracted to the sugary mixture and drink. They will carry it back to their nest and feed. The borax will poison them. There are you tube videos on this solution
05-29-2018, 08:36 AM
#31
We use Peppermint spray. Just a few drops of peppermint oil in water, and spray around, after a few days, no more ants..
05-29-2018, 01:06 PM
#32
Looks kind of like Acrobat Ants. They like to get behind the wall and eat insulation. We had them at one of our remote sites.
05-29-2018, 02:49 PM
#33
Originally Posted by ACJC
Looks like ants hopefully not carpenter ants
Those are carpenter ants, we know because we had them in the wall of our house.
Penny and Don Fuller
Greyhounds - Dubs
Bridge Angels Pi, Hannah, Mac and Essie
Shamrock 21SS
05-29-2018, 03:03 PM
#34
Originally Posted by doc73
I'd be shocked.. Since they claim you need to check the seals and caulk every 90 days (I think). I;m sure they willl try to weasel out somehow.
X2
Retired Auto body teacher
2021 Arctic Wolf 3550 Suite
2019 F-250 Lariat Super Crew 6.2
Having lots of Fun traveling with my wife
05-29-2018, 03:24 PM
#35
This is a serious problem as we have dealt with this. It is a clear sign of water intrusion It was our camera housing leaking that caused ours. As it had leaked from the day we picked it up and two separate dealers/repair shops couldn't find it, it ended covered under warranty.
First fix was a replacement of the luan skin and wall paper of the entire back inside. This was all FR would approve at that time. Within six months we had a delamination bubble on the exterior. We went back to FR because it was caused by the initial leak and they approved the replacement of the complete end of the rig. They had it shipped from the factory to Florida for installation.
You definitely want to caulk everything attached to the rig. The ants may be a side effect of them finding the moisture.
I would definitely contact FR directly as it occured during your initial warranty period. We were extremely pleased with how they handled this situation.
Best of luck.
05-29-2018, 06:00 PM
#36
Carpenter ant
I add that problem 2 years ago!
I try all recepies none to man but the solution was $400. Exterminator.
2 treatements, one right a way and second one, at the end of the summer.
You have to empty the trailer and live the trailor close for minimum 24 hrs when treated.
Then these ant like wet sterofoam so they will comme back if you dont removed that wet stuff and you cannot stop them from comming in from all small crack or opening in the trailor.
I found a roof leak that run down the wall and all the way to the floor.
I had to replace the complete floor of my trailor and doing so I could find plenty of dead ant nest.
Problem cured now!!!
05-29-2018, 06:15 PM
#37
These "ants" are usually found in wood that is damp/wet!!!!!!!! Always found around fire wood outside...
05-29-2018, 07:03 PM
#38
Bene Gesserit Rule
Katie & Frank
As above.
05-29-2018, 07:08 PM
#39
Yes. The ants are a bi-product from the leak.
2020 S.O.B.
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
05-29-2018, 07:16 PM
#40
Katie & Frank
Well from an RV tech colony of ants appears extensive. This did not happen overnight! Epidemiologist mentioned larvae could have been in wood when RV was built. We took delivery 1 year 3 days ago. Thanks for all your tips!
Frank & Katie
New Orleans, LA
