Old 06-10-2024, 08:23 PM   #1
Freetyme's Avatar
What stinks ?
Just returned from a 4 night stay. Strong holding tank odor from base of bathroom sink . First thought was the air admittance valve, and still could be the problem from what I'd researched. So is it possible while the fan is on to exhaust the smell and pull it back in another roof vent. Couldn't imagine it would be that strong. There's an aav under both the galley and bath sink. Is there also one for the black or is it shared with the grey ? Wondering if the roof tank vent smell is drawn in elsewhere by the fan running and if its directly related to a bad aav.
Freetyme is offline   Reply With Quote
Old 06-10-2024, 09:30 PM   #2
make sure you run water in the sink every couple of days
probably not a large P trap so water evaporates and exposes you to nasty smells
storage.... put plug in the sink smeared with plumbers grease
Shower drain can use water top up in the traps too
Tarpon Springs FL
2022 Salem 24RLXL
Aussieguy is online now   Reply With Quote
Old 06-11-2024, 04:03 PM   #3
Trailer Park Supervisor
NJKris's Avatar
If you have a p-trap, like Aussieguy said, no water in trap = bad smells. If you have a waterless trap, although it doesn't happen often, the lips inside that thing might be stuck open with debris or something. Again, not common. Lastly, if you have a Dometic 300, about 50% of owners have a big problem with trapped urine, lots of thread on this. Recommend you put your rig info in your signature for more specific help.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 06-11-2024, 05:14 PM   #4
Freetyme's Avatar
Kind of narrowed it down I think
Pulled the galley aav today, gunked up. Have two supposedly better quality ones on order. Will start from there. Lived the Dometic 300 nightmare 2 years back. The forum helped me discover that with a flashlight and mirror. Since replaced with the one piece porcelain, problem solved. Hope mfg's quit using that model, if not have it changed out before you buy a unit.
2018 Rockwood Mini Lite 2511s . Not sure how to navigate the site since the original dissolved to add this feature.
Old 06-11-2024, 05:28 PM   #5
NJKris's Avatar
Still surviving toilet odor free with our 300. (knock on plastic!), into year 6. I'm one of the lucky 50% so far. Glad you seem to have found issue.
Old 06-11-2024, 05:36 PM   #6
Unless you have a very leaky camper, any time you use your exhaust fan another source of air from the outside is needed. It can and will pull air in from any where it can get in including toilet seals and older vents.
2017 Wolfpack 315 Pack 12 5th wheel Toy Hauler
2013 F250 6.7 Diesel Dually 4x4
Odyknuck is offline   Reply With Quote
Old 06-11-2024, 06:13 PM   #7
Freetyme's Avatar
You are a lucky one. Possibly they changed a gasket design or type of sealant mid production after 50% complained about the issue. Anyways, there's bigger problems in the world than rv toilets .Happy Camping.
Old 06-11-2024, 06:35 PM   #8
NJKris's Avatar
Ya mean like this?? I LOVE having an RV. Keeps me busy so I don't kill myself.
Old 06-11-2024, 07:47 PM   #9
Freetyme's Avatar
Doesn't look good. I'm afraid to ask.
Old 06-11-2024, 07:54 PM   #10
NJKris's Avatar
Groundhog chewed holes through underbelly, maybe because was stinky. Discovered all the insulation in underbelly was soaked. Not sure if water leaked in from bottom of forward leading bulkhead or top. Got lucky, flooring was still not warped or rotted. At least now I know why I was getting a musty odor inside.
Old 06-11-2024, 08:21 PM   #11
Did you thank the groundhog?
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
chriscowles is offline   Reply With Quote
Old 06-11-2024, 08:24 PM   #12
NJKris's Avatar
I was thinking of thanking her with my .22 before I discovered the water damage. Now, I think that would be bad karma.
Old 06-11-2024, 09:51 PM   #13
Freetyme's Avatar
One way to discover an unknown issue. That sucks. Chipmunks around here. They don't leave much evidence on the outside, but raise hell once inside. Surprisingly it doesn't take a whole lot for a insurance co. to total a trailer. The cost to fix by a dealer can easily surpass the vehicle's value. Wouldn't be shocked to want payback on the varmints.
Old 06-12-2024, 09:44 AM   #14
NJKris's Avatar
Funny thing, I see chipmunks and grey squirrels running around outside of camper all day long, never a problem. Never got so much as a mouse in there. But groundhogs are another story. They cost me thousands of dollars in damage over the years. (Before this, just my cars). They LOVE the wiring, especially ABS wiring on vehicles they can easily reach. Thank you environmentalists for forcing industry to use soy in insulation vs. petro. Now my property is littered with lead and groundhog skeletons.
