Old 06-05-2024, 07:37 AM   #1
Wildwood 24RLXL bedroom TV mount?
I have a 2020 Wildwood 24RLXL. I'd like to mount a TV to the bedroom wall. There is a cable outlet and a power outlet located on the wall to the left of the bedroom window. So because of this I'm guessing a TV can be mounted. There is no sticker indicating placement of a TV mount. I've done the "magnet check" and there appears to be no metal plate located behind the wall. I have a swivel mount and a very light 32" TV. Any advice/information as to how to move forward would be greatly appreciated. Thanks.
CanadaJim is offline   Reply With Quote
Old 06-05-2024, 09:31 AM   #2
It is more than likely plywood. Try a stud finder, or just tap/press on the wall to see if you can feel where the backer is. If you think you found it, make a tiny exploratory hole to make sure.
2021 Forest River Wildwood 171RBXL
Towed by 2018 Toyota Tundra TRD SR5
reidfo is online now   Reply With Quote
bed, bedroom, mount, roo, tv mount, wildwood
