Originally Posted by AbdRahim
Thanks Finster. You may be on to something here. I looked again at the assembly on both windows. This one is mounted on the inside of the window frame. The one next to it is mounted on the outside. Perhaps re-mounting it on the outside would correct the problem. I have never drilled out a rivet before. Any pointers on how to do this?
From your pic, this one appears to be installed on the OUTSIDE of the frame. That's probably why it's not pulling the window in far enough. Move it to the inside to increase the "pull-in" when you close it.
Might also explain why the rivet is failing. When you tighten the window, all the force is on the two rivets. With the mechanism on the inside of the frame, the closing force would be taken by the frame and the opening force (which should be less) by the rivets.
2011 Traverse LT, 3.6L, FWD
