Originally Posted by dalford
Do not adjust tension as it is probably pretty tight but you might want to turn the roller wheel,that will raise the shade. Raise the shade 6” or so and then maybe you can pull it down until the release point is reached.
Yes - it is a roller shade. I tried what you suggested, but it won't move.
It was our Maiden voyage, so I will just add it to the list of stuff they need to fix.
Thanks for the suggestion.
