Old 10-11-2021, 06:33 PM   #21
Black H2o Flush line?
[QUOTE=5picker;2646632]One last point for those that only blow out...
Blowing out the lines with compressed air does not address the water pump or the suction/strainer screwed to the inlet side of the pump.
X2
My tt has black tank flush line routed up hill to the vacuum breaker, then is routed vertically to the black tank. I've use compressed air only. No antifreeze.The initial purge has water but diminishes to air only.
Your Thoughts ????
Richy R is offline   Reply With Quote
Old 10-11-2021, 06:58 PM   #22
Some suggest simply turning on the pump for a few seconds once the fresh tank is drained but again, I've seen several pumps and clear bowls cracked doing this and not using antifreeze.
Minutes, not seconds.
NavyLCDR is offline   Reply With Quote
a frame, frame, ram, winter, winterizing
