03-29-2021, 12:28 PM
Working on 12VDC wiring
New to 12VDC electronics, so excuse what may be a naive question. I’m going to be doing some small 12V mods to my 1640 PUP, and wondering if I need to disconnect the + lead from my battery before doing work? I’ve read some things saying you can cut/touch/work on 12V wiring that are live and not risk electrocution, but that seems hard to understand (given all my experience is with 120VAC.) Thoughts?
03-29-2021, 12:37 PM
That is generally true, but you can still damage/burn up things by sorting it to ground.
But yes you can usually touch it without harm, due to the lower voltage.
TT - 2021 Rockwood 2608BS
TV - 2020 F-250 XLT 4WD SRW 6.2L gas
03-29-2021, 12:44 PM
Overall though, to be safe, is there a mode of shutting off you recommend? Is there a shutoff at the fuses, or should I disconnect one or both leads at the battery?
03-29-2021, 01:30 PM
I generally disconnect the negative and tape with electrical tape or if I have a disconnect switch, I use that when I do electrical work. I have never had any arcing issues. Arching issues are the danger with 12v. Oh yes, I always wear safety glasses. It took a serious eye injury to knock some sense into me. LOL
03-29-2021, 01:31 PM
You could pull the fuse that is on the circuit you want to work on.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Patriot II
03-29-2021, 03:19 PM
The proper way to disconnect a battery is to remove the negative cable first then the positive. To reconnect the battery, the positive cable first, then the negative second. The same goes when connecting/disconnecting cables to charge a battery. To answer the question of disconnecting the positive cable to safely work on 12 volt, disconnect both cables.
03-29-2021, 04:32 PM
Just to calm your fear...
Just to calm your fear, have you ever held the a 9v battery--the kind with two snap fasteners on the end, used in smoke detectors? Put your finger across the two snaps? Nothing happens, right? 12v is not much more.
Neither voltage is high enough to force current through dry skin. If you were working with an open cut, you might feel a tiny tingle.
The IEC (international safety commission) has established 42 volts as the threshold for dangerous voltage. Anything below that is safe and does not pose a threat from electric shock. Electrocution is NOT an issue.
The work you will be doing is likely all downstream of a fuse. A short circuit would blow the fuse before you even see the spark. Nothing to worry about there.
This is not to say that 12v is completely harmless. The current that's available at the battery terminals and cables is substantial. If you did something like connect the ends of a wire to the two battery terminals, it would glow red pretty quickly and could cause a burn. You would likely yank your hand away before damage occurred. This situation occurs because there is no fuse installed. If you are doing to do any work on non-fused wiring, be sure to disconnect the battery AND turn off the converter's circuit breaker or unplug from shore power.
Larry
03-29-2021, 07:13 PM
Actually, it’s only necessary to disconnect one of the battery leads. Only one battery pole is fused. The only reason that the battery pole disconnection matters at all is in the case of a vehicle battery and in that case, it’s a matter of attaching the negative of a jumper cable to the vehicle frame, last. The reason for that caution is to attempt to move any arcing of the connection to be as far from the battery itself to mitigate the risk of igniting gasses from the battery electrolyte decomposition and having it go BOOM 🤯 Even that is not a likelihood.
Forest River Flagstaff e-pro 14fk
Ford Escape Turbo
03-29-2021, 08:49 PM
More specifically...
More specifically, think about this:
The negative battery cable is connected to the body and engine ground.
If you start to remove the positive cable first (or replace it last) and your wrench touches a chassis or engine part, you will get a nice big spark and arc. (I have a wrench or two with chunks out of them.)
If you remove the negative cable first (or replace it last), there is:
--No problem if the wrench on the negative terminal touches the chassis since they are already connected--no voltage difference, and
--No problem if the wrench on the positive terminal touches the chassis since the negative terminal is disconnected; there is no circuit, hence no spark or arc,
A dead or low battery gives off hydrogen--highly inflammable and explosive. All it takes is a little spark near the battery to ignite it. Ask my neighbor's husband who didn't know that and lost an eye checking water level in a dead battery by lighting a match and peering in.
Larry
03-30-2021, 04:43 AM
Larry is right on the money.
Disconnect your Neg cable first before doing ANYTHING electrical on your vehicle or camper.
Then replace that Negative cable LAST!!
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
03-30-2021, 06:24 AM
On a motorhome, be aware that disconnecting the ground from the house battery(s) will not prevent you from shorting the positive terminal to the RV. The chassis battery is also grounded to the frame.
2006 Dynamax Isata IE 250
420 Ah batteries
400w Solar
03-30-2021, 09:21 AM
Thanks all, so much help. This all makes sense. I will likely remove both disconnects (negative first) to be super safe, but one last question...
If I were to only remove the negative from terminal, do I have to be careful where I set it? If it touches the earth or the chassis, will I still have a live system? Where can I carefully place the negative lead? (I’ve only ever jumped cars, or fully removed leads to replace a battery.)
03-30-2021, 10:34 AM
As long as you remove the cable at the battery you can put it anywhere. The other end is already connected to the frame/body.
Joel K
2013 Coachman Mirada 29DSSE
03-30-2021, 03:35 PM
Ok thanks, I had understood that the negative was the ground. Probably safer just to disconnect all
03-30-2021, 04:21 PM
What was suggested in my post is the recommended and safest way to connect or disconnect a battery. The reason for the post was that the OP was asking to disconnect the positive battery cable. To prevent arching, the negative wire/cable should be the first to disconnect and the last to connect. I have done a fair share of wiring including converting a 6 volt system to 12 volts, vehicle wiring harnesses from scratch, trailer wiring, etc. And yes, the positive side has the fuse.
