Old 06-25-2018, 09:12 PM   #1
USMC0311's Avatar
working on the roof
I have a 2017 Wilderness 2750, I want to inspect the roof for cracks and put covers over my vents.
I'm a big boy, 6'6" and 320 pounds, is it possible that I may damage the roof by walking/kneeling on it?
USMC0311 is offline   Reply With Quote
Old 06-25-2018, 09:14 PM   #2
Same here curious.
djeazie is offline   Reply With Quote
Old 06-25-2018, 09:18 PM   #3
I would cut two 4x4 sections of 3/4 inch plywood and lay it on top of the roof so it does a better job distributing your weight then the thin play they have on top of the trusses.
Skyliner is offline   Reply With Quote
Old 06-25-2018, 09:19 PM   #4
6 foot 4 and about 280. never had an issue on any of my units. spread your weight through multiple contact points or large contact points. like your but or lower leg etc
Kimber45 is offline   Reply With Quote
Old 06-25-2018, 09:41 PM   #5
1/4" Plywood sheets 2'x2' with Thick Foam Pool Mat on top! Easy on your Knees and long enough for your Toe area also! If you want to "Walk" at 320# put on "Snowshoes"! Youroo!!
Old 06-25-2018, 10:01 PM   #6
BriaBeck's Avatar
Subbed!
Brian & Becky
2018 Avenger ATI 27RBS
BriaBeck is offline   Reply With Quote
Old 06-26-2018, 01:18 PM   #7
If you look at some of the Forest River brochures you'll see 3 or 4 guys on the roof installing stuff, so it's plenty strong.
For safety's sake, I'd use some thin plywood pieces to spread the weight out a bit. 2'x2' should be plenty big.
Gotta go campin!
Old 06-26-2018, 01:42 PM   #8
JJaxon's Avatar
Not all roofs are built the same. Some are very stout, some are not. Using something to distribute your weight is a must. My BIL needed his new covers installed on his new toy hauler 5r, and he is 300lbs. Im 250, and did it for him. His new roof had more flex in it than my 12yo toy hauler roof. Go slow, and if you think it doesn't feel right, back up and rethink it. Find a nephew, teenager, neighbor to assist. Those vent covers are not complicated to install. You can supervise from a ladder and coach someone half your weight without worry. Do it in the shade or morning before it gets too hot to be on the membrane.
John
2019 Ram 3500 CC 4X4 Cummins 6.7l
2020 Fuzion 369 toy hauler
JJaxon is offline   Reply With Quote
Old 06-27-2018, 11:46 AM   #9
Tom48's Avatar
I am 265 and feeling the roof move under my feet is scary. I have resorted to coaching a smaller adult child from a nearby ladder and try to stay off the roof.
Tom48 is offline   Reply With Quote
Old 07-03-2018, 02:13 PM   #10
Never had a problem, just try to keep my feet near the joists.
ray98 is offline   Reply With Quote
Old 07-04-2018, 04:24 PM   #11
Senior Junior Member
Hexnut's Avatar
More advice...
I am only 150# so I don't worry, but if was heavy I would distribute my foot load with a couple 2'x2' pcs of 1/2"-3/4"plywood with cushion material UNDER the plywood. Most roofs are arched and w/o the cushion, the foot load will not be adequately distributed and would still be applied at a point until the roof flexes. Just my 2 cents worth.
[B]2022 Rockwood Signature 8262RBS
Hexnut is offline   Reply With Quote
Old 07-14-2018, 09:41 PM   #12
Snow shoes
Kuba is offline   Reply With Quote
Old 07-15-2018, 11:39 PM   #13
I’m I’m 230 and my Catalina flexes more than I am comfortable With. This issue is the 3-4 feet between supports. I walk on 2x4s
quicky06 is offline   Reply With Quote
roo, roof
