Originally Posted by chief5631
I take it if I have a 15k dometic on a 2018 coachmen concord with 30 amp service I cannot install another ac?
My 2015 Berk 34QS has two Dometic AC units and the front it is a heat pump. Both are 15,000 BTU. On my most recent trip, I attempted to run both AC units while on 30 Amp power. The first time it didn't work, and the second time it did.
Moreover, for the time it did run both AC units, we were also able to also run the residential fridge and an ANOVA Sous Vide cooking unit that can draw up to 800 amps. Went out for the afternoon and never blew any of the fuses. And we didn't draw any fault codes on the thermostat.
I had the ME-RC unit set to expect 30 Amp power when on shore power. Note that the two Dometic units are connected to each other for control purposes: the front unit controls the rear unit. Presumably, this prevents them from trying to start at the same time. I'm sure that they can't both start at the same time on 30A.
I'm not sure what the difference was between the two situations, but it is likely that the voltage couldn't keep up when I attempted to run them together the first time. The Fault Code E7 on the Dometic CCC control may just come on to indicate that the voltage was too low to start the unit.
When I did get both units working the second time, I checked the voltage in the coach when all was running and noticed that it was a steady 110 volts.
–Gordon
