Old 05-28-2024, 10:40 AM   #1
390QS roof
I am told the roof is soft, and should be repaced on my 2008 Berkshire 390QS.
Any reference of place to provide this service and at what cost.
Thank you
Jcattley is offline   Reply With Quote
Old 05-28-2024, 01:34 PM   #2
bikendan's Avatar
Moved thread from the Forum Administration/ News/ Member Accounts section of the Forum to the Motorhome section's Berkshire sub-forum for better help from other Berkshire owners and factory support and because the post has nothing to do with the Forum Administration/ News/ Member Accounts section.
Old 05-28-2024, 05:01 PM   #3
Himcules's Avatar
Thank you
you should have a full fiberglass roof sitting on top of framing rib trusses. what do they mean it's too soft?
i have a 2013 390bh and the roof is entirely fiberglass. should it have any cracks/leaks it should be a simple fiberglass repair. if not, i'm taking it for flexarmor spray (if i don't upgrade to a newer coach lol)
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 05-28-2024, 11:06 PM   #4
Thank you very much. I really appreciate your info.
Ill check for flexarmor, again thanks
Old 05-29-2024, 01:32 AM   #5
bikendan's Avatar
Thank you
Who told you that the roof is soft?
Old 05-29-2024, 09:23 AM   #6
Commercial Member
The roof on the Berkshire even the earlier modes all utilized a Filon pebbled type fiberglass roof. A membrane type EPDM roof is not utilized on the Berkshire, Charleston brands
Lincman983 is offline   Reply With Quote
Old 05-29-2024, 11:07 AM   #7
Thanks for the info, so i assume the fiberglass roof deck is 1 piece, over trusses.
It seems, my unit had a crack
with the previous owner, and was patched with a membrane, and caulking, but not well done.Suspect that there is humidity between roof and headliner.
Old 05-29-2024, 11:24 AM   #8
Commercial Member
Whomever did the repair should have used a resin cast for the repair. Attached is how the roof is constructed as you can see no EPDM or rubber membrane is used.
Name:	Roof Breakdown.jpg
Old 05-29-2024, 12:46 PM   #9
Rednick69's Avatar
I have a 2008 360QS and my roof is aluminum. I would assume his is as well.
2008 Berkshire 360QS w/MBE926
Rednick69 is offline   Reply With Quote
Old 05-29-2024, 12:50 PM   #10
bikendan's Avatar
The person you quoted, is a factory rep.
Old 05-29-2024, 12:53 PM   #11
Rednick69's Avatar
I know, and his information is incorrect on at least 1 2008 Berkshire which could make him wrong with the person seeking help.
Old 05-29-2024, 01:45 PM   #12
Commercial Member
It has an aluminum frame and backers with a fiberglass outer skin.
roo, roof
