Old 10-20-2020, 01:32 PM   #1
Adding light to the stairs grab handle
2104 390FL Berkshire - I recently added a blue LED to my existing plexiglass stair grab handle. The project was fairly simple since it was already prewired.
To find the LED bulb search on Ebay for "RV Replacement 86430 LED"
Name:	Blue LED Handle.JPG
ID:	241581   Click image for larger version
Name:	grab handle LED.JPG
wdweldon is offline   Reply With Quote
Old 10-21-2020, 08:07 AM   #2
SeaDog's Avatar
Looks good you might consider posting the steps involved for other Berk owners
Retired Navy
2016 Flagstaff 26 FKWS
Old 10-21-2020, 10:40 AM   #3
To install remove the 4 bottom bracket screws and verify you can see the wires inside the chassis opening. Installation requires you cut the existing wires end connectors and using 2 small wire nuts attach the new LED. The LED will fit flush pointing up into the clear section of the grab handle.
Old 10-22-2020, 01:55 AM   #4
Why
Why wasn’t a light installed at the factory? Anyone check with engineering?
Trappfarmer is offline   Reply With Quote
Old 10-23-2020, 02:35 PM   #5
Where does the power to the wires come from?
jdkbrooks is offline   Reply With Quote
Old 10-23-2020, 02:41 PM   #6
The switch marked Aisle controls the power.
Old 10-23-2020, 05:21 PM   #7
So is it turned on with the outside light switch. I have the same handle and have read that a lot of these handles are wired for power and i would steal you're ideal.
Old 10-23-2020, 06:55 PM   #8
Our 2020 40E is already working from the factory. You can’t see it from a distance because the adjacent Berkshire emblem light is so bright. Operated by the external switch.
Old 10-23-2020, 07:11 PM   #9
ernest917's Avatar
I’d gave thought ur 2104 would have ALL the bells and whistles!!!! Lol.....
ernest917 is offline   Reply With Quote
light
