Old 01-28-2021, 11:19 AM   #1
Air Return Ducts in 2019 Berkshire
How do I remove the ceiling return covers on my 2019 Berkshire XL to remove and clean or replace the filters. It appears they either snap in or perhaps slide to remove to get to the filters. Didn't want to try to pull too hard and break any clips that hold the cover on tight in the ceiling.
radams4x is offline   Reply With Quote
Old 01-28-2021, 11:44 AM   #2
Being newer, yours may be different but mine are held by quite strong magnets near each corner. There is a metal plate screwed to the ceiling. I start at one corner and carefully work it along. I think too much force would crack them so easy does it. Those magnets are pretty strong. I’ve cleaned mine probably half a dozen times and they’ve never been too bad. If yours are the same working from one edge/side should do it.
2016 Berkshire XL 40A towing 2020 Jeep Wrangler unlimited.
Prior to this Jayco fifth wheel: 24' Eagle, 30'Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 01-28-2021, 06:30 PM   #3
Maingler's Avatar
Its strong magnets. Just pull 1 corner.
Maingler is offline   Reply With Quote
berkshire
