Old 05-28-2016, 09:32 AM   #1
mikeborny's Avatar
Air suspension not inflating!!! Any suggestions.
Just picked up RV from storage and have no suspension, very rough ride.
Mike & Amy + 3 and the dogs!
2014 berkshire 390bh-40
mikeborny is offline   Reply With Quote
Old 05-28-2016, 09:40 AM   #2
klucas's Avatar
Some times you have to turn off the leveling system, turn back on, let pressure build to blow off then hit retract again. Worked for me before.
klucas is offline   Reply With Quote
Old 05-28-2016, 09:44 AM   #3
tmmar's Avatar
Hit retract all again then wait for the air bags to inflate. I usually need to hit retract all twice when starting out.
Tom and Margaret
2014 Berkshire 390bh-60
Old 05-28-2016, 10:01 AM   #4
mikeborny's Avatar
Thanks, that what freighttliner had me do and I am back to inflated!
Old 05-28-2016, 10:02 AM   #5
KennyGolub's Avatar
X2. Not all the time, but on occasion
Ken & Laurie
2019 Entegra Aspire 44W
2020 RAM 1500 Laramie
KennyGolub is offline   Reply With Quote
Old 05-28-2016, 11:00 AM   #6
I always pull in slides then start engine.... Then when air pressure is good retract jacks.
Jc
2014 400BH-60
jcowles3 is offline   Reply With Quote
Old 05-28-2016, 11:04 AM   #7
accumack's Avatar
I always auto retract then hit each leveler for about 2 seconds manually. Then go outside and make sure the RV has raised up. Easy to see on mine if I can get my hand between the tire and coach the airbags are inflated.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
accumack is offline   Reply With Quote
Old 05-28-2016, 11:19 AM   #8
mikeborny's Avatar
So after i got suspension up and inflated again, could not get the emergency flashers to go off. Anyone else have an issue with that? You pull out to turn on, but would not go off when pushing in.
Old 05-28-2016, 11:20 AM   #9
accumack's Avatar
You need to turn a turn signal on I usually put the right one on it cancels the flashers. It took me a bit to figure out.
Ham KG5LTL.
Old 05-28-2016, 11:34 AM   #10
DJP6371's Avatar
Happened to me
You only have a finite amount of time from activating the levellers up, before starting the ignition.
Freightliner help told me to activate the levellers up and then start engine right away. It sends an electrical signal to reverse the actuator valve that drained your bags when you levelled and allows the suspension to start airing up.
DJP6371 is offline   Reply With Quote
Old 05-28-2016, 11:57 AM   #11
mike.t's Avatar
What did Freightliner say?
2018 Wilderness 2450FB
2021 Chevy Silverado 1500 3.0 Duramax 10 speed
2021 Chevy Traverse LT
2012 Dodge Challenger
If you get to thinkin' you're a person of some influence, try orderin' someone else's dog around.
mike.t is offline   Reply With Quote
Old 05-28-2016, 11:58 AM   #12
Cancel flasher with turn signal. Left or right doesn't matter.
Paul
2015 XL 40QL-60
2015 Jeep Wrangler Unltd. Sahara
Paulie Boy is offline   Reply With Quote
Old 05-28-2016, 02:49 PM   #13
We experienced same problem right after purchasing. Freightliner personnel crawled underneath front where they found 2 buttons. They depressed one which repaired our problem. They suggested starting engine before raising levelers. Haven't had the problem again. Knock on wood. Good luck!
RLHAMILTON is offline   Reply With Quote
Old 05-28-2016, 03:45 PM   #14
edgewant's Avatar
I always start the engine and let system 1 and 2 reach a minimum of 125 psi before hitting the retract all button. I too had an issue on our 2nd trip out and read the operators manual and it specified this procedure. Have yet to have another problem.
I also wait until I hear the air system relief valve pop before driving off that way I know the bags are inflated and I have reached normal operating pressure.
edgewant
2013 Berkshire 390RB-60
toad - 2002 Jeep Wrangler Sport
edgewant is offline   Reply With Quote
Old 05-28-2016, 04:27 PM   #15
dan-nickie's Avatar
Works every time for me.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 05-30-2016, 01:18 PM   #16
I agree with above posts. Just this past weekend I attempted to short cut the system by raising jack before airing up .... after riding the pogo stick I followed the above procedure and problem was solved.
Slides in
Air up
Jacks up
Air up again and on my way
lefaivre is offline   Reply With Quote
Old 06-04-2016, 06:30 PM   #17
NewBerkFamily's Avatar
Us too. We retract the levelers 2X, check them outside, and hold the engine at about 1600 rpm in neutral until we hear the puff. Watch the gauges and if one dips back down, do it again until you hear another puff. Should be good to go after that.
2016 Berkshire XL 40BH - 380
2015 Jeep Wrangler Unlimited
NewBerkFamily is offline   Reply With Quote
suspension
