Old 09-29-2020, 09:00 PM   #1
Bed slide 2014 390FL Berkshire
I just had our bedroom slide repaired, I was told the motor pulled away from its mount. The slide seems to work well however when fully extended I can pull on the lower cables and cause a little slack? Is this a issue?
wdweldon is offline   Reply With Quote
Old 09-30-2020, 02:56 PM   #2
Commercial Member
WD,
do the cables sag more than 1 inch? IF so they may need tightened. I would take it back to the repair facility and have them address the issue.
Lincman983 is online now   Reply With Quote
Old 09-30-2020, 03:12 PM   #3
thank you
2014, bed, berkshire, slide
