01-29-2016, 04:41 PM
Berk Door Won't Stay Open
I'm sure our entrance door used to stay open while parked. With friction or something probably from that bar across the top.
Now when I open it all the way it will kind of bounce back a little bit if I don't hold it open. Just the slightest breeze will close the door.
Any tips on the Berkshire?
Dan
2014 Berkshire 390RB-60
01-29-2016, 05:06 PM
Dan, mine seems to click in place and hold. Will be going to storage facility this weekend and will check it out.
Rich
01-29-2016, 05:23 PM
I think I remember a thread here that addressed that issue. Maybe a splitring that need to be spread a bit if I remember right. I could be wrong.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
01-29-2016, 05:27 PM
Ts seems like I remember some thread also. I'll look a little harder. Oops I can't send from my phone so I'll have to wait till tomorrow when I get on a laptop.
Dan
01-29-2016, 05:30 PM
Berkshire 390QS
Just make sure you have a extra key hiden outside your coach so you don't get locked out. Been there and done that one too many time.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
01-29-2016, 06:59 PM
Me too! 40 degrees, raining, and in my pajamas. :-)
Dan
01-29-2016, 07:07 PM
Retired IT Manager (NERD)
Dan,
I saw this fix on the forum. I am not having luck finding it though. It was this past summer.
01-29-2016, 07:11 PM
Wasn't it Phil that had the problem and fix?
Ham KG5LTL.
01-29-2016, 07:17 PM
My door use to close. If you look at the top of the door there is a pin that fits into the bracket that keeps the door from opening to far. I used a vice-grip pliers to squeeze where the pin goes in. Was not easy but corrected the problem. I suppose you might be able to wrap the pin with something to achieve the same results but I figured whatever I wrapped it with would just wear off.
01-29-2016, 07:45 PM
There's a little iron spacer on that pin, it has a slit in it. Take a screw driver and pry it out a little.
2013 Berkshire 390BH
01-29-2016, 07:48 PM
That is how I have always fixed mine. Just spread the roller a bit with a flat screwdriver. I tried it last week on mine again and it seems to not be working now. Not sure what's up but will look at it later.
01-29-2016, 08:16 PM
I see the spacer and will try that tomorrow.
I just wrapped a little duck tape on it for now.
Dan
01-30-2016, 09:02 AM
Dan, I would advise on doing that. I pried the barrel spring and a piece dropped out. The barrel spring is high tempered and will not take bending. I had to have the total arm replaced back when I was under warranty.
I am not sure if the design has changed, but I found that the barrel spring had a rivet to the round barrel that it surrounded and that probably is where the weakest link is. I do not know of a fix other then replacing.
Not a very good design; even my new one has a mild wind, closing the door. Opening hard against the stop also shortens its life.
Hank
Gale & Hank- 2012 Berkshire 390BH
