Yes...assuming yours is like mine...... I will attempt to describe, and the terms are meant to be descriptive not always correct....(see quotes)
There is a bracket on the wall with two horizontal "bars", about 14-16" long and about 1/3 in from the top and 1/3 from the bottom. The tv has "hooks" on the back that hang on the top bar. On the bottom there are two pieces that slide under the bottom bar and then are secured with set screws. They are allen wrench screws and you need a long allen wrench and very thin hands to come up from the bottom of the TV and loosen the screws. Once loose, the bottom of the TV comes out towards you and you lift the whole thing up and off the bracket.
I suggest getting a mechanics mirror and a flash light to look up behind the TV from the bottom to locate the set screws.
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
