i did a frig conversion on a south wind, several things need to be addressed :
1. if not already equipped, a minimum 2000 w inverter.
2. 4 each 6 volt storage batteries, ( will run frig about 6 hrs)
3. remote (inside coach) inverter control panel.
4. not necessary, but I wired my new inverter into my existing intelc power management system. so I could detect
low batter power and use the auto gen start to charge frig
batteries .
5. and last but not least, find a residential refrigerator that
fits where the Norcold was. I found a 18 cub/ft Frigidaire
at home depot. getting it in the rv was a pain. we had a drivers side door, took door off and removed driver seat.
used two very large college football linemen. I’d no door,
then you will have to remove a window. good luck.
