Old 09-13-2020, 08:39 AM   #1
Berkshire 2014 390FL Fresh Water filling
How do I determine when the fresh water is full without running inside and watching the guage?
wdweldon is offline   Reply With Quote
Old 09-13-2020, 08:50 AM   #2
To keep it simple,
Know your gallons per minute fill rate. Will be most accurate at home.
Empty your fw tank.
Start your stop watch and fill your fw tank.
When you hit the gauge levels, record the elapsed time.
Now you will know how long it takes to reach a gauge level.
2006 Sunseeker 2860DS Ford V10 5 speed with Tow/Haul
Winegard T4 In Motion Satellite Dish
Furion Rear Camera, RecPro 70" Recliners
Mohawk Luxury Vinyl Plank Flooring
2013 AWD Acadia Denali, Blue Ox Equipped
ChrisParise is offline   Reply With Quote
Old 09-13-2020, 09:03 AM   #3
Originally Posted by parise View Post
To keep it simple,
Empty your fw tank.
As long as every single place you fill at......is exactly the same GPM as the one you used for the test.
TheWolfPaq82 is offline   Reply With Quote
Old 09-13-2020, 09:13 AM   #4
Yup, I said that. Will be most accurate at home.
Old 09-13-2020, 09:29 AM   #5
What I've done with every single popup, TT, that we've ever owned, is to run the water till it came out of the "Overflow Tube" underneath and then I turned off the water.
Old 09-13-2020, 09:44 AM   #6
I bought a small in-line water meter at Ace I just screw in and keep track of. On my coach the overflow tube is routed poorly so I prefer to keep track of the gallons (although an estimate rather than exact) that way. On past rvs we’ve had I just watched the overflow tube.
2016 Berkshire XL 40A towing 2020 Jeep Wrangler unlimited.
Prior to this Jayco fifth wheel: 24' Eagle, 30'Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 09-13-2020, 09:48 AM   #7
Exactly where is the overflow hose? Do you suggest I overfilling once to find the hose?
Old 09-13-2020, 10:01 AM   #8
Yours may be placed differently, but on my coach I can see the hose when I open the compartment holding the fw (and the water pump). Every overflow tube I’ve seen comes out below where the fresh water tank is.
Old 09-13-2020, 10:10 AM   #9
I overfilled every time I filled the tank. Always knew the tank was full then.
Old 09-13-2020, 02:24 PM   #10
Mmnsc's Avatar
Be careful with Berkshires of that years. The overflow does not always allow water out and if you look at the fresh water tank some greatly expand upward with a big bulge
Mmnsc is offline   Reply With Quote
Old 09-19-2020, 08:30 PM   #11
What he said, but...
On my 2013 390FL, if I overfill, the tank does expand...then the overfill tube works but turns into a siphon partially emptying the tank. So I just watch the tank level behind the gray/black water drain and make sure I never overfill. Pain watching it, but I have the time...I'm retired!
Phil & Kathi
USAF/USAF Civil Service Retired; 2013 Forest River Berkshire 390FL, 2011 Equinox, TireTracker
KPfulltimers is offline   Reply With Quote
Old 10-17-2020, 12:47 PM   #12
gasman94's Avatar
I've got the same coach. I just open the door on the passenger side covering the water tank and pump. Prop it open and watch the progress. I did forget at one time when I was filling and it did fill up and look like it was going to burst. I won't do that again.
Rich
gasman94 is offline   Reply With Quote
Old 10-27-2020, 01:59 PM   #13
My fresh water tank bulges when I fill it, but I don't worry about it.
Basically, the tank is a wide rectangular box. The water pressure in the tank will naturally push the wide roof up. This wouldn't happen if the tank had a spherical shape, but that wouldn't be very efficient.
The tank looks like it is a pretty strong roto-molded plastic, so I don't think it will burst from the pressure of gravity in the tank. We aren't pressurizing the tank above normal atmospheric pressure as long as the overflow tube lets water out.
–Gordon
Gordon Sick, Calgary (51° North)
2015 Berkshire 34QS
The Manual I wrote for our 34QS:
https://www.forestriverforums.com/fo...ml#post2579202
Toad: 2019 Ford Ranger XLT 4x4; Formerly: 2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
2014, fresh water, water, berkshire
