11-19-2015, 07:17 PM
#81
I was shortest or second shortest all through grade school and High school then I had a growth spurt at 18 and got to 5'7". So I know all about it I thought I would have a little fun. Sorry guys.
2011 Berkshire 390-rb-40, upgraded tires and front axle airbags, 2012 Jeep Wrangler 2 door, Blue Ox baseplate and BlueOx aladdin tow bar, Blue Ox Patriot brake system, wiring run through right frame rail and homemade led taillight bar.FB.
Ham KG5LTL.
11-19-2015, 07:34 PM
#82
Our 2014 tilts and telescopes also. Might just need a good tug if it was never used. Try pulling up or pushing down ( in case it is up ) after depressing small pedal.
Joe & Lori
2014 Berkshire 390 RB-40
11-19-2015, 07:47 PM
#83
Ok as to moving my seat forward. I add a couple pictures. There is no way that this can ever slide from under the washers. The front two bolts have it secure. ATTACH]94625[/ATTACH]
11-19-2015, 07:48 PM
#84
11-19-2015, 07:51 PM
#85
The engineer in me would like to see one solid plate capturing both bolts and across the seat plate.
Paul
11-19-2015, 08:43 PM
#86
Paul
I know what you are saying. And I may get around to doing that. But in no way can it move unless the front two bolts shear. Not sure what would make them shear ??
Russell
11-19-2015, 10:41 PM
#87
Originally Posted by CAT-RN
Ok as to moving my seat forward. I add a couple pictures. There is no way that this can ever slide from under the washers. The front two bolts have it secure. ATTACH]94625[/ATTACH] Attachment 94626
Thanks Russel. I like that. Will have to wait until spring when Cinderella gets her kiss
Rich
11-19-2015, 11:03 PM
#88
Originally Posted by Phil57
It does on mine. Yours doesn't? Mine is a 2011.
I really don't know if it telescopes, I never tried. will as soon as I pick it up at the shop.
Dan
2014 Berkshire 390RB-60
11-19-2015, 11:24 PM
#89
Holy Smokes! I just went outside and checked, and mine telescopes also! I have put 18k miles on it this year and that would have made my driving more comfortable! I need a facepalm emoji...
Thanks for the info!
Brian and Kelly
2016 Entegra Anthem 44B
2013 Jeep Wrangler Sahara Unlimited
11-20-2015, 10:23 AM
#90
As far as I know, the steering wheel on all Berkshires tilt and telescope. Mine does on my 2014 and did on my 2008 as well. That is how Freighliner builds them.
Tom and Margaret
2014 Berkshire 390bh-60
11-20-2015, 11:20 AM
#91
Mine telescopes now. Nobody said I had to use all my strength to free it from where it was🤕
Paul
11-20-2015, 11:23 AM
#92
Paul
Paulie maybe you need to hit the gym. This might help and you can do it in your home.
11-20-2015, 11:32 AM
#93
You guys crack me up!
Ham KG5LTL.
11-20-2015, 11:33 AM
#94
Hanoi Jane? You should be ashamed😡
Paul
11-20-2015, 11:38 AM
#95
Paul
I am most of the time.
11-20-2015, 11:50 AM
#96
Hey, are you guys serious about telescoping? If so, I need to go check mine.
Rich
11-20-2015, 11:54 AM
#97
Rich,
Definitely!! Yours should telescope. Press the pedal to tilt the steering wheel and pull up on the wheel.
Tom and Margaret
11-20-2015, 11:59 AM
#98
Rich
I don't think Rich trusts us. Have we ever led you wrong?
11-20-2015, 12:37 PM
#99
11-20-2015, 01:00 PM
#100
Hey Phil go check mine!! Its 1100 mile closer to you than it is to me. Ha
Russell
