Old 08-01-2024, 09:54 AM   #1
The Wanderer2's Avatar
Berkshire floor light
I need to replace the aisle light bulbs on my Berkshire. Need to know type of bulb and where to get it.
2019 Berkshire 34QS
2020 Grand Cherokee Summit
The Wanderer2 is offline   Reply With Quote
Old 08-01-2024, 11:25 AM   #2
Commercial Member
Is this the light you are referring to? If so the bulb is a 395 4 watt 12vdc bulb pics of both are attached. You might be able to purchase the whole aisle light assemblies from the Berkshire parts dept. Their number is 574-522-1747
Lincman983 is offline   Reply With Quote
Old 08-01-2024, 11:33 AM   #3
Thanks, that's it.
2019 Berkshire 34QS
Old 08-04-2024, 09:14 AM   #4
Anybody know where to get this bulb? I've looked at all the auto parts stores with no luck. I see bulbs on amazon, but not sure they will fit. I need direction to the right replacement. Thanks!
2019 Berkshire 34QS
Old 08-04-2024, 10:14 AM   #5
Mmnsc's Avatar
I bought similar light bulbs at a marine supply store. They use them in deck lighting and the navigation lights
Mmnsc is offline   Reply With Quote
Old 08-05-2024, 09:10 AM   #6
Commercial Member
Batteries and Bulbs Plus may have what you are needing. I needed a replacement light for a Dometic RV refrigerator and they found one that matched up via their cross reference. If they can't then you can order a whole light assembly from the Berkshire Parts Dept.
berkshire, floor, light
