Old 08-10-2017, 11:33 PM   #1
Berkshire Headlights
Yes I know that this subject has been brought up before, I tried to search for it but I had no luck. I have a 2016 Berkshire XL 40BH 380. I love the coach for the most part but night driving is out of the question as the headlight on High are not even as bright as the low beams should be. On the other post there were listed several fixes and I think someone even said what the original application for the light assembly was. If anyone has any information I would love to read what you have to say. This next spring I am taking the family from Northern Wisconsin to Disney World in Florida. Driving straight thru there and back, 3 drivers no problem. But for the night driving we will need to be able to see. Thanks....
Fkaske is offline   Reply With Quote
Old 08-11-2017, 12:08 AM   #2
Same issue on out 2015 BH. It's been to the dealer several times and even had the passenger assembly replaced. Now not only can I not see but the low beam went out for a second time.
teamromano is offline   Reply With Quote
Old 08-11-2017, 07:56 AM   #3
The easy fix is switching to Sylvania Ultra bulbs. Helps a lot but still not perfect.
zuckerburg is offline   Reply With Quote
Old 08-11-2017, 09:11 AM   #4
I'll have do a search for the switch. My lights are projector style and it doesn't look like you can just swap bulbs but that would be a quick kix/swap.
Old 08-11-2017, 04:16 PM   #5
I forgot they changed them in 2015. Mine is a 2011 and the headlights suck.
Old 08-12-2017, 09:56 AM   #6
Himcules's Avatar
the headlights are from a toyota highlander... i believe the part that fits a 2006. you can get aftermarket HID or LED highlander headlight assemblies that have superior low and high beams as a complete unit.
himcules (10x stronger than hercules)
2013 Forest River Berkshire 390BH-60
ex 2007 Jayco Greyhawk 31SS
Himcules is offline   Reply With Quote
Old 08-12-2017, 10:48 AM   #7
ceedog's Avatar
Switch to HID's. Amazon has them. They're plug & play.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 08-12-2017, 12:43 PM   #8
Himcules's Avatar
Got a link?
usually HID requires a big ballast and proper projectors. they aren't just bulbs...
Old 08-12-2017, 01:06 PM   #9
I believe the Highlander lights are for the 2008-2013. I think they changed to a Audi headlight for 14-16 or 17.
Old 08-12-2017, 02:09 PM   #10
Himcules's Avatar
yes you are correct.. i remembered the years wrong. thanks.
Old 08-12-2017, 10:28 PM   #11
Headlights
zuckerburg Do you know the year and model of the Audi that the headlight assemblies come from? Thanks.
Old 08-13-2017, 11:33 AM   #12
I believe it's a 2010 Audi A4.
Old 08-13-2017, 11:35 AM   #13
Old 08-13-2017, 12:51 PM   #14
ceedog's Avatar
The HIDs come with the ballast & they're about 2"w x 3"h x 1/4" thick.
Like I said they're plug & play.
Go to Amazon, type the bulb number & the correct kit will come up.
Old 08-13-2017, 03:36 PM   #15
BobbyJ
Bobbyj's Avatar
Drive up to a wall and check the alignment. That might contribute. They normally do a poor job of aiming headlights at the factory.
BobbyJ
Bobbyj is offline   Reply With Quote
Old 08-13-2017, 10:13 PM   #16
Geno
Fog Lights
Looking to change out my fog lights on 2016 Berkshire BH does anyone have any suggestions for replacements? Woking on my 3rd set they keep filling up with water. Yes i am putting silicone around the lens.
They are the long fog lights.
allman is offline   Reply With Quote
Old 08-17-2017, 10:14 PM   #17
Our 2015 Berk 34QS are from a Toyota Highlander 2001-03.
The passenger side headlight was badly fogged, and I was in Elkhart in July, so I bought a replacement from FR. The lights that came out were Eagle Eyes, which seems to be the major after-market supplier for headlights. They are manufactured in Taiwan and most Amazon and E-Bay searches seem to come up with that brand, even if they don't explicitly name the brand. In particular, FR doesn't use original Toyota parts, just the design.
The boys in the factory installed the light for me and I asked about the alignment. They say they eyeball it.
I subsequently put Eagle Eyes headlights in my 2001 Honda Odyssey. As installed, they are aimed very high. I lowered them and checked my results by backing away on a flat road from a wall. If the low-beam cutoff is rising as you back up, they are aimed high. If it is falling, they are aimed low. The trick is to find a very flat road with a wall at the end.
Gordon Sick, Calgary
2015 Berkshire 34QS
The Manual I wrote for our 34QS:
https://www.forestriverforums.com/fo...qs-191578.html
Toad: 2019 Ford Ranger XLT 4x4; Formerly: 2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
Old 11-06-2017, 10:19 AM   #18
CZNEDY's Avatar
We haven't driven at night yet so I don't know how the headlights are. Ours is a 2018 (first half of the year) 34QS and it looks like we have the Highlander headlights. I found the Sylvania Silverstar Ultra, 2-pack for $ 51.99
Part # 9006 and Advanced Auto.
2018 BERKSHIRE 34 QS
2016 Jeep Wrangler 75th and a
Cooler full of good ideas
Full Time in the Summer, soon
Part Time in the Winter
Days Camped, Not Enough
CZNEDY is offline   Reply With Quote
Old 02-04-2018, 10:46 AM   #19
SORRY BUT INCORRECT! The lights on the 2016-2017-2018 Berkshire XL coach is from a -
2008 Audi A4 - NOT the model you listed. There is a slight difference between those 2 light housings. The ones used by Forest River (2008 Audi A4) have a rounded curve upper inner corner. The light housing shown in your photo (which is a 2010 Audi A4) does NOT have this rounded upper inner curved corner, it is a sharp corner. Aftermarket housings are available from Amazon $239.00 a pair. NOW THE CONUNDRUM - If you're having trouble aiming the lights that because on the Berkshire the light housings are located on the front of the body at a point that's 4 inches higher and 22 inches wider than where they are located on the Audi. Seems like Forest River chose this item for it's appearance and did not do their proper due diligence - engineering wise on these headlights as there is NOT enough adjustment using the aiming screw jacks in the headlight housings to compensation for the the increased height and width the lights are mounted at on the Berkshire coaches. Forest River will have to come up with a recall and re-design the brackets where the housings mount to the fiberglass nose with brackets that have slotted holes to allow the entire housing to be adjusted inside the body headlight opening.
TampaGary is offline   Reply With Quote
Old 02-04-2018, 04:08 PM   #20
The change of headlights happened around 2015. I have talked to people that own that year and some have the Audi and some have the Highlander headlights. So be careful on absolutes when talking Berkshires. My 2011 is more like a 2012 than a 2011.
berkshire, light
