Old 05-28-2024, 11:45 AM   #1
Berkshire honking issue
Hello, our rv has started honking while sitting. Sometimes the lights flash while honking and sometimes it doesn’t. Anyone know what this means???
brendahallstrom is offline   Reply With Quote
Old 05-28-2024, 12:05 PM   #2
Mr. Dan's Avatar
Thread has been moved from the Forum Admin, News and Member Account Info forum to the Berkshire forum since this is not an issue with the member's account.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 135/'23 = 78/'24 = 41; Booked for 2024 = 55
Old 05-28-2024, 12:53 PM   #3
Commercial Member
what year and floorplan is the coach?
EricB West berkshire is offline   Reply With Quote
Old 05-28-2024, 01:41 PM   #4
Mr. Dan's Avatar
I found 2021 40C in another post.
Old 05-29-2024, 09:27 AM   #5
Commercial Member
Does the coach have keyless entry with the key fob remotes? If so the battery in the transponder may be ending it cycle life and may need to be replaced.
Lincman983 is offline   Reply With Quote
Old 05-30-2024, 08:06 AM   #6
This drove me nuts for about 2 years. Neither Freightliner nor FR Plant in Elkhart found a solution.
Since I did the following, I have not had another instance of the horn blowing for no reason.
I removed the dash access cover and found a small hole in the AC hose line. Once I taped it up, no more problem. Guess it was either low temperature on an electronic component or condensation. I think more condensation because it would often start hours after arrival at a park. If it happened while I was driving, it was in the late afternoon. I really thought it was a wire grounding out but I could never find a culprit in the steering column or where the wire bundle runs behind the small drawers in the console. On the afternoon events, I tried to follow water drips from the AC air intake but the horn wiring is not located underneath that point.
I hope this helps
BetttyReady20 is offline   Reply With Quote
berkshire
