Old 06-04-2023, 11:30 AM   #1
Berkshire XL
I just Purchased a 40D, the front overhead defroster fans keep blowing the fuse when switched on. Any suggestions?
Tony Ramirez is offline   Reply With Quote
Old 06-04-2023, 01:14 PM   #2
bikendan's Avatar
Moved thread from the Tech and Repair section to the Berkshire sub-forum for better help from other Berkshire owners and factory support.
Sent from my SM-G781U using Forest River Forums mobile app
Old 06-05-2023, 07:59 AM   #3
Commercial Member
What year is your Berkshire 40D? it could be a faulty fan motor pulling too many amps and tripping the fuse.
Lincman983 is offline   Reply With Quote
Old 06-05-2023, 08:23 AM   #4
Quick easy way to test this
Here's a quick, easy way to measure that current.
  1. Get a multi-meter that has a 10A (10 amp) scale. Most of them do, even the $7 ones.
  2. Plug the black probe into the COM terminal.
  3. Plug the red probe into the 10A terminal.
  4. Turn it on.
  5. Make sure the fan is off.
  6. Remove the fuse.
  7. Plug the multimeter probes into the fuse socket. The probe tips will fit nicely into the curled part of each fuse socket terminal.
  8. Turn the fan on BRIEFLY and read the current from the meter. If you see blinking "1", the current is over 10 amps. Most fans draw less than 10 amps.
Larry
"Everybody's trailer is not like your trailer."
Larry-NC is offline   Reply With Quote
Old 06-06-2023, 11:01 AM   #5
Dodge Guy's Avatar
Unplug the fan and see if the fuse still blows. If it does then there is a pinched wire. If it doesn’t blow then the fan is bad.
2012 Georgetown XL 350TS, Hellwig front/rear sway bars, Sumo Springs, Blue OX True Center steering damper
2013 Ford Explorer LTD toad, Roadmaster Stowmaster 5000, VIP><Tow Brake
Better to have a bad day of camping than a good day at work!
Dodge Guy is offline   Reply With Quote
Old 06-07-2023, 05:52 AM   #6
Berkshire XL 40D
It is a 2019 XL 40D.
I will try and test current draw this weekend, thanks. I didn't see an easy way to "unplug" the fans, haven't unmounted them. If they are drawing too much current, I'll probably need to replace them. Any suggestions on nice looking, quality replacements?
berkshire
