Old 02-23-2024, 09:54 PM   #1
Tony Ramirez's Avatar
BIM next to Hydraulic Pump
Great forum, lots of useful info. Got this coach less than a year ago, slowly getting all the wish list items done without breaking the bank all at once. I noticed there is a BIM mounted next to my Jacks & Slides Pump, not sure why. The schematic doesn't show it, the Hot coming from my 150 Brkr goes to it, then one comes off and goes to the Slide Circuits and the other goes to the rear distribution panel. Any idea what this is for or does?
ID:	297208   Click image for larger version
ID:	297209   Click image for larger version
Tony Ramirez is offline   Reply With Quote
Old 02-23-2024, 10:53 PM   #2
bubbles's Avatar
That's not a BIM. It's a Battery Disconnect. Typically to disconnect sources via a remote switch. Iam not familiar with your coach however.
Old 02-23-2024, 11:26 PM   #3
You're right, because I was trying to trace down everything I mislabeled it when typing.
Any idea why it would be there?
Old 02-24-2024, 06:42 AM   #4
It's your battery disconnect relay. The switch near the door controls it.
It turns off power from the house batteries to the RV 12 volt systems.
Twinboat is offline   Reply With Quote
Old 02-24-2024, 09:56 AM   #5
Okay, thanks for clearing that up. So if I Turn the disconnect knob in the battery bay, it does the same thing?
Old 02-24-2024, 12:08 PM   #6
Maybe .
The knob may be the inverter disconnect or it may be the chassis battery disconnect.
Old 02-24-2024, 07:09 PM   #7
The knob will kill the gen and the jacks, along with the 12volt, the salesman switch just the 12V. If I'm reading it the schematic right. Not at the coach now to try it. Thanx.
Old 02-26-2024, 08:49 AM   #8
Commercial Member
That switch is the battery disconnect switch and it works in conjunction with the switch by the entry door. It is a remote type switch that turns off 12V power to the coach instead of acually having to physically turn off the house disconnect manually.
Lincman983 is offline   Reply With Quote
Old 02-27-2024, 06:56 AM   #9
The one circled is the Knob disconnect but in the schematic, on the 2/0 red wire should also have the remote Salesman switch drawn in.
Thanks again everyone.
Tony Ramirez
2019 Berkshire 40D
pump
