Booster Antenna's
I was able to figure out a way to get my cell and WiFi booster wire from the antenna's to inside the coach. I drilled holes through the flooring behind the access panel below the washer dryer, just next to the water heater. It comes through into the last storage compartment. I then sealed them up to prevent critters. I will manually connect them (depending on what needs boosting) when I get to my destination and attach the expandable pole to the upper ladder via clips. When not in use I just velcro wrap them up. After I took this picture I wrapped the wires in Gardner Bender.
Cell - WeBoost Drive Reach RV
WiFi - Alfa Camp Pro 2
