Old 05-25-2023, 08:12 AM   #1
Berkshire07's Avatar
Brochure 2007 Berkshire MBE 926
hello, we have a Berkshire 2007 with MBE 926 engine and MH 3000 gearbox. Does anyone know how much GCWR we have. My Europe papers are wrong, normally I should have 38000 lb? Does anyone have another 2007 Berkshire Brochure? Thank you and regards Emmanuel
Berkshire07 is offline   Reply With Quote
Old 05-25-2023, 08:53 AM   #2
Diesel Rep West Coast
should be stickers with the weight somewhere near the driver seat. could be on the wall next to the drivers seat or in the overhead compartment above the drivers seat.
Eric B FR Diesel is offline   Reply With Quote
Old 05-25-2023, 08:59 AM   #3
here's the 2007 brochure.
Old 05-25-2023, 09:05 AM   #4
Thank you, unfortunately the stickers have been swapped and I have data from Cummins.
Old 05-25-2023, 09:07 AM   #5
thank you very much for the brochure
Old 05-25-2023, 09:07 AM   #6
by what you are describing with chassis and motor and transmission are you sure you don't have a Charleston? the 2007 charleston was built with a Mercedes motor, and a 3000 series transmission, while the Berkshire was built with a Cummins ISB motor and a 2500 transmission. what is the floorplan? should have a number on the outside by the entry door. Also I have attached the Charleston brochure for a 2007.
Old 05-25-2023, 09:15 AM   #7
thank you yes we have a Berkshire with MBE 926 engine with MH 3000 gearbox. The floor plan is 360 QS
Old 05-25-2023, 09:54 AM   #8
if you have the titles the chassis vin number should also be on those and you could reach out to FCCC at 1-800-ftl-help and they should be able to get you the chassis spec's for your coach. Also I believe the GVWR is printed on the chassis title, which is an incomplete title, and then there will be a title from forest river that has the floorplan on it.
Old 05-25-2023, 10:14 AM   #9
I'll get in touch with Freightliner, Forest River has confirmed the chassis number and type for me. many thanks for your help
Old 05-25-2023, 10:28 AM   #10
Commercial Member
If you have the VIN number we can check and see what the GCWR possibly is
Lincman983 is offline   Reply With Quote
Old 05-25-2023, 10:34 AM   #11
Commercial Member
According to the brochure the GCWR is 33,000 lbs. and the Mercedes MBE 926 turbo diesel
· 7.2 liter
· 330 HP @ 2200 RPM
· 1000 Ft. Lbs. Torque @1600 RPM
· Allison 3000MH 6-speed transmission was an option on that model in place of the Cummins ISB 5.9L
Old 05-25-2023, 10:48 AM   #12
· 7.2 liter
· 330 HP @ 2200 RPM
many thanks for the help. According to the option it is a Mercedes MBE 926 turbo diesel
7.2 liters
•330HP @ 2200RPM
• 1000 ft. lbs. Torque @1600RPM
• Allison 3000MH 6-speed transmission
• 10,000lb receiver hitch. GCWR 38000lbs ? That would be better for me than 33000lb. Since I have 6700 lb with trailer and car.
Old 05-25-2023, 10:49 AM   #13
Z35423
Old 05-25-2023, 12:43 PM   #14
Rednick69's Avatar
Where are you seeing the 38000?
2008 Berkshire 360QS w/MBE926
Rednick69 is offline   Reply With Quote
Old 05-25-2023, 12:46 PM   #15
Commercial Member
It is a 33,000 lbs GCRW. The hitch capacity doesn't add to the GCRW. Not sure where the OP got the 38,000 lbs from.
Old 05-25-2023, 12:58 PM   #16
Thank you very much. I have now written to ForestRiver and am waiting for the answer. As soon as I know more I will let you know.
Old 05-25-2023, 01:01 PM   #17
in the 2007 brochure under chassis options it says: CHASSIS OPTIONS
• Mercedes MBE 926 turbo diesel
7.2 liters
•330HP @ 2200RPM
Old 05-25-2023, 01:10 PM   #18
Commercial Member
Eric and I both are from Forest River
Old 05-25-2023, 01:12 PM   #19
Commercial Member
7.2 liters
•330HP @ 2200RPM
The 10,000 lb hitch is optional equipment and isn't standard like the Mercedes diesel engine which also is a selectable equipment option.
Old 05-25-2023, 01:18 PM   #20
my trailer hitch is 10000 lb so i thought 38000 lb.
berkshire
