I spoke to Danny two days ago about the brownouts. Here is what is happening and how to correct the problem. The engineers set the threshold too low to detect a drop in voltage. It only takes a nano second of low voltage to trigger a brownout. They have corrected this, but you need to install a new display. Danny will send you a new display free of charge, however you need to send him a picture of your software display.
Take a picture of the following display: click on the gear wheel in the upper left hand corner, click on the time tab towards the bottom on the left hand side, click on the upper part of the display (I think it says setting time), now the display will show all kinds of information and a sw number. Send this picture in an email to Danny, he will send out a new display and you return the old display to him. To remove the old display take a small screwdriver and undo the four tabs on the left & right side of the unit. Remove the bezel around the display, now unscrew the four screws that hold the unit to the wall, remove the unit and disconnect the telephone like jack on the back. Take the new unit, plug in the cord, push the unit back into the wall, screw in the four screws and snap on the bezel. Presto.
Here is Danny's email address:
d.dinovo@precisioncircuitsinc.com his phone is 630-515-9100 ext 704 another email address is:
tech@precisioncircuitsinc.com
