Anyone made an attachment that will allow u to fill ur freshwater tank “without” using the fill in the water compartment?????
I’m thinking it would be really simple to make a fitting that would screw onto the fitting shown in the above picture.... put a female hose fitting on the opposite end and u should be able to shoot water directly into the tank....
This could be used in an emergency situation when ur on the road and suddenly ur check-valve on the fill fitting stops working..... AND no one near you has a replacement available....
Think I’m gonna make one when I get close to a Lowe’s or Home Depot so I can get the materials.....
