Old 03-22-2021, 09:21 AM   #1
Cable signal
On my 2014 390FL when I connect cable TV to my rig what is the path to the TV? I don't see any switchers?
wdweldon is offline   Reply With Quote
Old 03-23-2021, 10:39 AM   #2
Commercial Member
It should run from the cable in jack to the splitter that is in one of the compartment then out to the tvs. make sure the antenna booster if off or the cable signal will be weak or no channels will be found during a channel search on the tv
Lincman983 is offline   Reply With Quote
Old 03-23-2021, 11:04 AM   #3
thank you for the info.!
cable
