Originally Posted by edgewant
You might try unbolting the u-bolt that acts as part of the latch. If your battery compartment is like mine and in the same relative position you can access the nuts on the u-bolt from below.
I stand corrected. That’s one of the few that can’t be accessed. I once had that issue with my wet bay door and FR was telling me to carefully bend the door. I wound up accessing it thru the sewer port.
I’m not sure how I’d do the battery compartment. Maybe something flexible so you could push the plunger up to release the latch.
