With the Truma should be a black round control that plugs into the right side (looks like a telephone jack). It should either be mounted somewhere in the coach area-probably inside close to the water heater; or maybe in a drawer as lots of folks elect not to install it. If it’s plugged in sometimes you need to reset or mess with it. If not plugged in make sure the filter is clean and seated. If it’s air locked or it has a sail switch for water flow and propane before it’ll fire. If the coach hasn’t been used recently and it was winterized I’d also make sure that the bypass valves are correct.
Sorry I can’t help with the other issue, but encouraging no water intrusion. I’ve heard that the glue can sometimes lose it’s poop but that looks like a sharper bend than I would think.
2016 Berkshire XL 40A towing 2020 Jeep Wrangler unlimited.
Prior to this Jayco fifth wheel: 24' Eagle, 30'Designer, and 40' Jayco pinnacle.
