Originally Posted by Maingler
It should be 2.25#s.
Do you have power on both sides of pressure switch?
If so need to check driver interface plug under dash.
Freightliner had an issue with there control module.
The technician said voltage at front preasure switch but did not say which side, only 2 wires at the switch. Their Snap On scanner did not work for freightliner. I did scan for codes and my scanner & showed no codes,, but the scanner does not check specifically for A/C codes. Is the control module out of stock with supply issues?
