Old 08-05-2024, 10:33 AM   #1
Chassis Air Pressure
Seems like it is taking longer and longer for the air pressure system to fill the air bags and for the pop off valve to pop, even at fast idle. In fact on the last start I got near max pressure BUT the pop off valve never opened. It took a short drive to get to the max pressure. Is there a spec on how long it should take to pressurize to max/normal pressure? Called Freightliner and they said call Cummings, called Cummings and they said it is a Freightliner issue. Any suggestions I should have the techs look at during next service visit would be appreciated.
2017 Berkshire XL 40A & 2017 Ford Focus SE
I Built and Fly - Van's Aircraft RV-12
Ham Radio - W9EAA
MartyQ is offline   Reply With Quote
Old 08-05-2024, 11:43 AM   #2
ceedog's Avatar
Are you trying to air up with the jacks up or down? Some Berk models air up quicker with the jacks down.
It ain't easy being me...I've tried.
ceedog is offline   Reply With Quote
Old 08-05-2024, 12:50 PM   #3
Commercial Member
I would have them check out that air valve for one. It sounds like the pressure switch isn't cutting off at the limit. here is how to air up the leveling system;
HOW TO INFLATE AIR BAGS
1-START ENGINE
2-POWER ON LEVELING SYSTEM
3-HIT RETRACT ALL BUTTON
4-LET SYSTEM CYCLE
5-POWER OFF LEVELING SYSTEM
6-CHECK AND SEE IF AIR BAGS ARE INFLATED
Name:	Air valve .JPG
Lincman983 is offline   Reply With Quote
Old 08-05-2024, 01:23 PM   #4
Lincman...
That is the procedure I use. You refer to an air valve. Which one? My problem is the air pressure is not building as quickly as it did in the past. The photo you attached is associated with the ride height or something else? Thanks.
Ham Radio - W9EAA
Old 08-05-2024, 01:27 PM   #5
To inflate the air bags I have to retract the jacks.
Ham Radio - W9EAA
Old 08-05-2024, 02:10 PM   #6
Commercial Member
Originally Posted by MartyQ View Post
Lincman...
The valve pictured is the auto dump valve for the air ride system. They can get sticky and will not trigger the compressor to air the bags up properly.
Old 08-06-2024, 11:54 AM   #7
ceedog's Avatar
Lincman,
Where is the valve located?
Old 08-06-2024, 01:00 PM   #8
Commercial Member
Lincman,
Should be on the frame rail close to the air bags. It is installed on the chassis by Freightliner.
Old 08-06-2024, 03:35 PM   #9
Tony Ramirez's Avatar
Lincman, Is there something that needs to be done to keep them from getting "sticky"? And if they are sticky, what's the fix?
Tony Ramirez
2019 Berkshire40D,380HP,1100w Solar, 920AHs LiFePo4
'04 37'Sunvoyager-Sold, '92 30' Pinnacle-Sold
Tony Ramirez is online now   Reply With Quote
Old 08-07-2024, 07:22 AM   #10
Commercial Member
That would probably be a question better suited for Freightliner. We don't see many issues with the chassis portion of the coach as we only do the "house" side and not the chassis, driveline and suspension components as those are installed by Freightliner.
Old 08-07-2024, 07:51 AM   #11
ceedog's Avatar
Lincman,
Copy & thanks for the info.
pressure
