Old 06-21-2013, 09:05 PM   #1
City water connection
Pretty basic question here......So I just realized that we have never hooked up to the "city water" connection before as we have been boon docking it for the 10 months we have owned our Berk. So camping in a real campground tonight with wifey asleep next to me and not wanting to disturb her by turning on a light and checking the manual, I am wondering when hooking up to the city water connection do I turn the water pump on too? When hooked up does it dump to tank or does it run direct to coach? Is there a diverted valve I need to turn or anything I need to do? What's the procedure guys? This campsite living is pretty fancy. We are used to racetracks, parking lots and being in the middle of nowhere.....lol!
James
2008 Berkshire 360QS-40
"If you can't fix it with a hammer, you have an electrical problem"
speedmerchant is offline   Reply With Quote
Old 06-21-2013, 09:11 PM   #2
ernest917's Avatar
No pump needed when hooked up to city water... Don't forget to switch your water heater over to electricity also.....
ernest917 is offline   Reply With Quote
Old 06-21-2013, 09:12 PM   #3
ernest917's Avatar
Also - in your water management center, you have a connection marked "city water" Just hook hose up to that.... No switches to throw....
Old 06-22-2013, 06:39 AM   #4
How do you switch it to electric?
James
Old 06-22-2013, 06:44 AM   #5
Truth B Towed's Avatar
On TT, we have to open up the panel outside to the water heater, the switch is in there to turn electic on.
2008 Silverado 5.3 tow package
2013 Roo 25rs
2014 nites booked 10
Truth B Towed is offline   Reply With Quote
Old 06-22-2013, 06:54 AM   #6
Toad Haul's Avatar
But, can you leave the water heater on gas? Don't know if there's a difference other than paying for propane. Does the city water connection require switching to electric?
Darren, Donna & The Wieners
Toad Haul is offline   Reply With Quote
Old 06-22-2013, 07:20 AM   #7
No. City water does not require electric. Run on propane if wanted.
Quicker recover time.
cwalters2112 is offline   Reply With Quote
Old 06-22-2013, 08:06 AM   #8
I would recommend using a water pressure regulator when hooked up to 'city water'.
Old 06-22-2013, 08:32 AM   #9
ernest917's Avatar
Absolutely on the regulator!!!!!
Old 06-22-2013, 09:03 AM   #10
Yeah have a regulator, but not sure how to switch heater to electric. Others have commented but is their a switch on the Berkshire?
James
Old 06-22-2013, 09:06 AM   #11
ernest917's Avatar
Go outside your Berk, open cover for waterheater, look lower left and you will see an on/off switch.... Turn it on....
Old 06-22-2013, 09:08 AM   #12
ernest917's Avatar
You've had your Berk 10 months???? You really need to take some time and real your manuals.... It's a great coach and you need to be able to enjoy all its features....
Old 06-22-2013, 09:27 AM   #13
Berkshire 390QS
NO3putt's Avatar
A couple of things before using electric HW, 1. Make sure your tank is full. 2. Remove the heater vent on outside, on ours, lower left side you will see on/off switch, usually with a cotter pin, remove pin and switch to on. We have used ous with both gas and electric on at same time when we want the water to heat us faster.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 06-22-2013, 09:59 AM   #14
mjracsj's Avatar
What year is your coach? Newer ones will have a gas only "on demand" water heater that does not use electric.
mjracsj is offline   Reply With Quote
Old 06-22-2013, 10:30 AM   #15
Be careful to test your regulator using on demand hot water. If it restricts flow too much, you the heater will not turn on and thus, no hot water. I don't know what the threshold is, but I know if the flow is too slow, it will not heat.
JJ
JJvike is offline   Reply With Quote
Old 06-22-2013, 09:23 PM   #16
Thanks, I have that switch on all the time, thought that was for the gas igniter. Like I said never had the need to try the electric hot water till today. The gas works really well and never had hot water with just that switch turned on. Always use the switch inside that fires the gas. Maybe an issue there.
James
Old 06-22-2013, 09:59 PM   #17
ernest917's Avatar
Switch inside fire the propane and has nothing to do with heater when you're heating the water Ruth electricity.... I seldom use the propane for the WH unless I'm boondocking and have no electricity.... I save my propane for other things - running frig as I traveling down the road, furnace, etc.
When I plug in at a CG, I turn the switch on the water heater to the on position and forget about it until I'm ready to leave and then I turn the switch off.... It's just part of the routine I go through when setting up at a CG....
Old 06-22-2013, 10:00 PM   #18
ernest917's Avatar
I hate "autospell"!!!!!!!!
Old 06-22-2013, 10:07 PM   #19
Herk7769's Avatar
No. the city water connection should provide all the pressure you need.
Here is a diagram that explains how it all goes together.
Name:	Water and Sewer Diagram.gif
HAM CALLSIGN - KC3FFW
Old 06-22-2013, 10:28 PM   #20
ernest917's Avatar
It's really a simple issue - hook up the end of the water hose that has the water pressure regulator attached to it to the CG faucet.... Then, hook the other end to the city water connection in the water management bay of the Berk.... I suggest you purchase a 90 degree hose fitting to use inside the compartment to keep the hose from kinking. (Bring the water hose into the water management bay through the opening in the floor of the compartment).... Then turn on the faucet... No water pump is needed as long as you're hooked up to city water....
Then go around to the water heater and flip the power switch to the on position.... No need to use the WH switch on the inside control panel...
