02-19-2017, 02:13 PM
Condensation in the Head Light
I have a lot of condensation in my head light lens only on the right, any suggestions. Thanks in advance
02-19-2017, 04:04 PM
Dragonship Captain
This is a recurring theme, if you do a search you will find discussion on the subject.
Some folks have removed the unit and sealed the you know what out of it and report good results.
There are different degrees of water intrusion. Some report an inch or more of water standing in the unit. That's obviously a serious leak.
Others, like yourself and myself report mere condensation.
My personal theory is that the unit is indeed NOT sealed and filled with dry air like one would wish, and that there is SOME exchange of air with the outside, but not enough to keep it ventilated. So, at times humid air gets in there, then the temperatures drop and the moisture in the humid air condensates.
If you look on the backside of the light there are a number of "tubes" in the molded plastic that lead into the unit. There are little plastic caps on them. I have successfully used a hair dryer, some hose and duct tape to force warm air into the unit until it clears.
So, some claim a fix, I say there isn't and that it's a matter of treating it when it happens.
Since I dried mine out last fall (when temperatures first dropped) they've been clear all winter.
Next time I clear them I will document and put it on my blog.
On edit..... doing that right now.
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
02-19-2017, 04:33 PM
Dragonship Captain
02-20-2017, 08:04 PM
You can spray Windex around the perimeter where the lens glues to the housing and gently blow air through the bulb opening and if there is a leak it will bubble in that area. You can take some clear silicone and seal the area at the bubbles.
02-20-2017, 08:33 PM
While you are chasing down the leak, don't forget to check your blinker fluid: https://youtu.be/KBv69yr67YY
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
02-20-2017, 09:16 PM
Dragonship Captain
Make sure you have a LARGE tube. It's not just the seam of black and clear. There's holes everywhere.
02-20-2017, 10:55 PM
Might suggest a vacuum over the holes to suck out the water.
2017 Puma 297RLSS
02-21-2017, 09:48 PM
Dragonship Captain
Make sure that's a shop vac.
02-23-2017, 09:55 AM
Sounds like a GM product !!!
02-23-2017, 10:15 AM
Just as confused as you
Originally Posted by SailorSam20500
I would guess that blinker fluid is not only for blinkers any more.
Richard & Jill
03-03-2017, 10:21 AM
Your profile says you have a 2012 Berkshire. But which model do you own?
Karen and Rick
2020 Forester 2251SLE
Previous: 2018 Berkshire XL 40C
2011 Honda CR-V toad
03-03-2017, 10:39 AM
Originally Posted by rknola
your profile says you have a 2012 berkshire. But which model do you own?
12 390 bh
03-03-2017, 11:08 AM
12 390 bh
will send you a PM
Karen and Rick
03-03-2017, 11:46 AM
sorry, first PM on 2011 Berkshire. Second PM correct, I promise!
Karen
Karen and Rick
Karen
Karen and Rick
