Old 01-15-2014, 04:04 PM   #21
Happy Keystone Owner
dbarr's Avatar
If the island to the right is empty use it.
'15 F150 Ecoboost Maxtow Scab '19 Keystone Laredo 225MK
Days camped 2020-37 2019-36, 2018-24, 2017-46, 2016 -56, 2015-33,
2014-47,
Years camping....55
dbarr is offline   Reply With Quote
Old 01-15-2014, 05:52 PM   #22
Berkshire 390QS
NO3putt's Avatar
We don't use DEF, however was at a truck stop and the DEF pumps where only on the drivers side and a truck pulled in with his DEF fill on his left, he just asked if we could wait a bit and used the DEF pump that was on our pump, no problem, he filled his DEF tank, paid and then we filled up. Truckers have the same problem depending on the truck.
2015: 188 days, 2016: 72 days, 2017: 185 days: 2018 182 days
2019: 156 days (2009 Berkshire, 390QS, and toad)
Old 01-16-2014, 07:54 AM   #23
mjracsj's Avatar
Originally Posted by Phil57 View Post
Well I alway use the truckers lane with no issues. I tried to stretch the DEF hose and the one I tried wouldn't reach. Other locations may? The DEF is always on the wrong side. It's there for the truckers. You can fill from both sides but the DEF is so far as I have seen not on the passenger side. My idea worked ok but I need a better pump. The end would just curl up and the pump is a PIA. I will look for a better option.
I got this pump for $30 on Amazon. It runs on 2 D batteries. My wife said it looks like a child's toy but it works really well and it had very good reviews. It has a solid tube that reaches all the way into a 5 gallon can and has a handy little nozzle. I use mine for easy gas fills (no more spills or mess!) and liked it so much I ordered another one to have as a spare. I only put about 2000 miles a year on my coach so for me it is not a big deal to just get a few gallons of DEF at the auto parts store but if you are filling from a 5 gallon can this might work perfectly for you.
mjracsj is offline   Reply With Quote
Old 01-16-2014, 08:38 AM   #24
camper1999's Avatar
Originally Posted by Ford Idaho View Post
No one should feel out of place for using a truck island at anytime.
The truck stop is there to provide a service if you need that service use it!
X2 I use the truck lanes all the time. It is a lot easier in and out. I never get a dirty look. I refuel and leave.
2011 GMC 2500HD Diesel
Old 01-27-2014, 09:54 PM   #25
Phil, just bite the bullet and pull in backwards. I've never had so much as a dirty look from any trucker. If you're really brave, grab the orange cone and put it right behind the last truck in the lane. My wife does this an waits by the cone while I lurk nearby waiting for the lane to empty.
Of course, I will ONLY do this when the TS is not very busy. If trucks are lined up 4 deep on every lane, I just move on to the next TS.
Boowho??
boowho is offline   Reply With Quote
Old 01-27-2014, 10:01 PM   #26
Originally Posted by tmmar View Post
I don't understand the need to pull into the fuel lanes backwards. The DEF tank is on the passenger side of my coach towards the rear. I have 2 fuel fills on my coach- one on each side toward the front. If I pull into the fuel lane where the fuel hose is on the passenger side, wouldn't the DEF hose be on that side also. I may have to pull the coach up so that it reaches but I'm not sure why I would need to pull into the fuel lane backwards.
Nope, DEF pumps are ONLY on the drivers side at every TS I've ever seen.
Maybe being an ex 18 wheeler driver I'm too blase about going through backwards.
I don't get distressed unless I have to go inside and see how all those poor drivers have to live ( and how *I* used to live); about makes me puke!!
Boowho??
Old 01-30-2014, 10:16 PM   #27
Future Berkshire Owner
Joker's Avatar
I like the hand pump idea for topping off the DEF tank. I'm going to have to look into getting that equipment as it's anxiety provoking trying to find a station to pull through backwards. Usually about the time I get turned around, someone else has pulled into that lane!
I, too frequent the truck lanes as the RV islands have much slower pumps. Regardless if you're using the RV island or the truck lanes or the check out at Walmart, it is, I think, an expected courtesy for you to be quick about it and not do things that waste the time of people behind you.
That being said, thanks for the pump idea and sorry for wasting anyone's time with redundant information!
Joker is offline   Reply With Quote
Old 01-30-2014, 10:27 PM   #28
Joker I don't think you wasted anyone's time. I just reread the topic and am going to order that pump from amazon. Skip the cheaply made hand pump from Walmart POS
Old 02-01-2014, 09:08 AM   #29
Texas Bohunk's Avatar
Local Auto parts store has the 2 1/2 gal. containers for $14.99. Flying J has it at the pump for $2.79 gal That's a pretty big difference.
2014 V-Cross Platinum 365VTSB
2002 Frontier 305S bumper pull
2013 Dodge Ram 2500 4X4 6.7 Cummins Automatic Trans. AFE aftermarket air filter, Curt 24k slider hitch
Texas Bohunk is offline   Reply With Quote
Old 02-01-2014, 09:37 AM   #30
tmmar's Avatar
I used the truck lanes for DEF. Had to pull in going the opposite direction. Did it when there were a number of open lanes and didn't have any problems. Worked out really well.
Tom and Margaret
2014 Berkshire 390bh-60
Old 02-01-2014, 12:32 PM   #31
X2
Old 02-01-2014, 01:00 PM   #32
ernest917's Avatar
I am soooo glad that I don't have to deal with DEF.... One less thing on my plate....
ernest917 is offline   Reply With Quote
Old 02-01-2014, 01:47 PM   #33
I have never owned a MH without it(that shows how new we are) but don't find it to much if a hassle. I will find a pump or pull in backwards or figure it out. I would not pick a unit out based on having DEF or not. What I enjoy is the lack of smell coming from the exhaust. I hate the diesel smell. I wish the generator had it also. If you have ever been to a FMCA rally with no electric you will know what I mean. The smell is awful.
Old 02-26-2014, 03:41 PM   #34
Hallen01's Avatar
I only go into big rig fuel stops, and advise the cashier that I'm going to go in backwards (i.e. I circle around to the exit side and drive into the bay outlet, having first set a small traffic cone in the entrance to keep it clear until I can pull in.
After I fuel (I can fuel from either side), I pace off the distance I need to reset the cone at, so that I can pull up with the DEF tank adjacent to the DEF pump.
Some fuel stops require two separate transactions.
I carry a store-bought jug in case I get caught with no DEF in sight, but never use it, except to replace it with new near the end of the season.
Hallen01 is offline   Reply With Quote
Old 02-26-2014, 03:48 PM   #35
tmmar's Avatar
Thanks all who replied. I have been pulling in 'backwards' when filling up with DEF. I can usually find a lane that does not have any truckers waiting to fuel. So far so good. Just hope that other fuel retailers start installing DEF pumps as well.
Tom and Margaret
Old 02-26-2014, 04:49 PM   #36
Diesel 5th wheeling for the first time this year with a Ford 250 super duty. DEF inlet (and fuel) are located on the driver side and at the truck stops have the DEF pump o driver side and fuel on both sides. Just pull straight in on fill up. Way to go Alan Mullaly and crew.
Bonnie & Bob
2014 Flagstaff 8528IKWS 5'er with revolution hitch
tv: 2014 Lariat Ford F250 power stroke
L'il Red Wagon 6.5 bed
bobby75 is offline   Reply With Quote
Old 02-28-2014, 08:59 AM   #37
I-RV's Avatar
I picked up two 2.5 gal blue plastic kerosene containers at Walmart and keep them empty most of the time. I also pull into the truck lane backward when possible, but if not, I can fill my containers at the same time that I am fueling up.
Gale & Hank- 2012 Berkshire 390BH
I-RV is offline   Reply With Quote
Old 04-16-2014, 05:46 PM   #38
JTN8's Avatar
FYI, just left walmart and they sell DEF by the motor oil now. It was $11.99 for a 2.5 gallon jug. Bought two and they have the extended filler hose one them so it filled my tank quite easy. I squeezed the jug as I was filling my tank and it went really quick with no hassle or spills.
Old 04-17-2014, 07:48 AM   #39
I-RV's Avatar
If the jugs are reuseable, you can refill while you are getting diesel and keep one or two in the RV or at home. If kept in a garage, it will be good for a year.
pump
