Old 07-12-2013, 09:57 PM   #21
Future Berkshire Owner
Joker's Avatar
Just a tip...when I load the fridge for the first time on a trip, I put a few frozen items in both the fridge and freezer. I usually have a gallon jug frozen solid from my home freezer that I put in the RV freezer and two smaller vessels in the fridge (I use the mostly square plastic containers of cocoa almonds or other nuts they sell at SAMs)
I think this helps me conserve propane and also get the food to a safer temperature faster.
Joker is offline   Reply With Quote
Old 07-13-2013, 02:20 PM   #22
billygo3251's Avatar
I use two small fridge fans, keeps the temp between 33-35 degrees
billygo3251 is offline   Reply With Quote
Old 07-13-2013, 02:34 PM   #23
A 2 fans on the outside blowing on the coils and 2 on the inside for circulation will work wonders on cooling. We can get our frig down to 29 and the freezer to 4 with the 4 fans running in 80° ambient with temp setting @ 3. Both compartments are empty and doors have been closed for several days.
When we start using it, both compartments will raise about 4°-5° normally.
Old 07-13-2013, 08:45 PM   #24
2011 Berkshire 390BH-60
TaterColo's Avatar
What do these fridge fans look like and where did you buy them?
TaterColo is offline   Reply With Quote
Old 07-13-2013, 09:03 PM   #25
TURBS's Avatar
I usd a 120 mm computer fan on the inside.
Old 07-13-2013, 09:05 PM   #26
TURBS's Avatar
And two 80mm fans on the outside.
My frdge cools to 32º in 6 hrs.
