Old 08-19-2020, 02:51 PM   #1
Dust from Gravel Roads in Bus
Hi FR Berk owners,
My first post. Bought a 2020 34QS this spring and love it!! The only thing that is a real nuisance (particularly for my wife) is the dust that comes in the bus when we travel down gravel roads. We live in a very rural part of Manitoba and it is 4 miles to pavement from where we live, not much choice in the matter. We have joined the seal on the front door which did help but the dust us still getting in. Any suggestions on where to start looking for leaks or is this something that we are going to have to live with it
Thanks,
Interag is offline   Reply With Quote
Old 08-19-2020, 03:16 PM   #2
I added automotive expanding sealant all around the outside of the step box, and any suspect places in the firewall as well as areas under and in the basement. I did it mostly for cold air, but it works for both.
2016 Berkshire XL 40A towing 2020 Jeep Wrangler unlimited.
Prior to this Jayco fifth wheel: 24' Eagle, 30'Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 08-19-2020, 04:52 PM   #3
Not just gaps in various body panels and undercarriage but also through storage compartment door seals.
You name it and it can be a source of dust. ESPECIALLY roof vents.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change)
Old 08-19-2020, 06:10 PM   #4
Cool
Originally Posted by Interag View Post
Hi FR Berk owners,
...the dust that comes in the bus when we travel down gravel roads. We live in a very rural part of Manitoba and it is 4 miles to pavement from where we live...
Thanks,
oh man!!! I love Manitoba!!!! No, not really, sorry.
It was a DUST nightmare on the crazy dusty road that led us into and out of the Angle Inlet(Minnesota, for those that don't know this 'crazy' section of the state, totally surrounded by Canada!), and 'Tom's Corner phone booth Border Patrol 'video' check in/out', and it engulfed our rig, too! It was a really annoying mess!
The reality is that the rear diesel and the 'build' of the RV on the chassis is what creates the ability for this 'very fine dust' to get brought up into the living areas. The turning of the engine and rear fan, the movement of the wheels on the dusty terrain, and the 'vacuum' that is sometimes created by the shear nature of 'driving'. There is probably not a SINGLE RV in this world that is 'dust proof', but yes, some are 'better' than others - a front engine gas motorhome would probably not complain about this 'problem'. CRAZY!!
The Turners...
formerFR is offline   Reply With Quote
Old 08-20-2020, 01:11 PM   #5
AKA: 'tiredTeacher
awellis3's Avatar
...Any suggestions on where to start looking for leaks or is this something that we are going to have to live with it
Thanks,
Find an RV repair shop that has a Sealtech. It pressurizes the interior allowing the tech to locate leaks using soapy water or tracer elements.
This problem is why the Aussies run some of their off-road trailers down the road under positive pressure.
Wright and Penny
(with Fitz and Lizzie, the camping kitties)
Richmond, Va.
2010 Tundra 4X4 5.7L V8
2014 Rockwood 2604WS
Life is a cruel teacher. She gives the test first; the lesson then follows.
awellis3 is offline   Reply With Quote
Old 08-21-2020, 06:27 AM   #6
If you have a fantastic fan, or similar, you might try reversing the wires to make it blow air from the roof into the RV. It should help to pressurize the RV and hopefully keep most of the dust out.
mnoland30 is offline   Reply With Quote
Old 08-21-2020, 10:32 AM   #7
Diesel Rep West Coast
is the dust in one area over the other? OR is it all over?
Eric B FR Diesel is offline   Reply With Quote
Old 08-21-2020, 12:48 PM   #8
The dust is now worse at the back of the bus and at back of bathroom vanity , the entry door is better since we sealed gap in door molding. See attached pics prior to door seal repair
Name:	entry door dust -1.jpg
ID:	237203   Click image for larger version
Name:	entry door dust.jpg
Old 08-21-2020, 01:02 PM   #9
Is the vent fan and the window both closed in the bathroom? The fan vent should be able to get adjusted on the multiplex. Also the window closed all the way? I ask because these should be the only two potential entry points in the bathroom. Also in the rear of the coach is the dust in bedroom or in the rear storage area?
Old 08-21-2020, 01:38 PM   #10
RKNOLA's Avatar
Foam sealant under bottom of coach.
Karen and Rick
2020 Forester 2251SLE
Previous: 2018 Berkshire XL 40C
2011 Honda CR-V toad
RKNOLA is offline   Reply With Quote
Old 08-23-2020, 07:54 AM   #11
The bathroom fan vent and all windows were closed. The dust appears to be coming from under the vanity on right hand side and from under the bed.
