Had the same issue - hills/mountains raising the temperature. Even had to slow way down or stop to let it cool below the red. Hopefully my quick fix is your solution..... My radiator fins became plugged with road grim on the engine side - particularly where the fan blows into it. Take a garden hose and spray (gently) straight through your radiator (while standing outside.) The stream should spray through your radiator fins. If it is plugged, most of the water will bounce/pour back. Keep spraying to loosen the grim. Eventually, you'll start to see black grim flowing off your radiator and then the stream will pass through the radiator. It was a huge relief when this fixed my problem! The worries about the costs of a cracked head, fan clutch, etc., went out the window.
Jeremy & Monica, seven children, plus our spoiled dog
2011 Berkshire 390BH-60
Towing 10 passenger Chevy Express conversion van
