11-10-2020, 10:05 AM
equalizer/leveler system
We have a 2011 Berkshire 360QS. Our control board to level the R.V. won't light up an function. I found one 20a. fuse in the luggage compartment where the hydraulic tank and hoses are located.Is anyone aware of an other fuse I could check? Hope the controller or board near the driver's seat isn't bad.
11-11-2020, 09:25 AM
Commercial Member
Strato,
that 20A fuse is strictly for the leveling system. Does the controller light up?
11-11-2020, 11:17 AM
equalizer system
no, not at all.
11-11-2020, 04:05 PM
Commercial Member
Strato,
Are the front two slides working? Those slide rooms are hydraulic and use the same pump as the leveling system.
11-11-2020, 05:44 PM
equalizer system
Didn't get that far, I'll check.
11-12-2020, 12:20 PM
equalizer system
I have 12 v. at the panel, the equalizer system web page says in this case the panel is bad. My brother is going to look at it, an electrician, but I
most likely have to order a new one. About 300 bucks.
12-06-2020, 03:18 PM
equalizer system
We got the system working today. After replacing the control board next to the driver's seat, that didn't solve the issue. Next we replaced the main control box located in a luggage compartment, attached to the ceiling of the luggage compartment. That solved the issue.
12-08-2020, 08:05 AM
Since you have your issue fixed I hope I'm not derailing your thread. I have a 2008 360QS and I have a few questions for you or anyone that will answer.
Can your Equalizer board function without turning on the ignition?
12-08-2020, 09:29 AM
Commercial Member
Rednick69,
I believe the control panel you have is a power gear. Does the panel say Equalizer on it? If you could post a pic of what is currently in your coach, thank you.
12-08-2020, 09:31 AM
I brought it with me today so I could try to research it some.
2008 Berkshire 360QS w/MBE926
12-08-2020, 09:42 AM
Commercial Member
Rednick69,
the key has to be on to retract the jacks.
12-08-2020, 09:45 AM
Thank you, that's what I assumed.
Do you know if this board will still have power going to it with the key off? Reason I ask is because I have lights on it with the key off.
If so, maybe I have an issue with this control. If not, maybe I have issues elsewhere.
12-08-2020, 10:23 AM
Commercial Member
Yes, you are correct. The control pad will have power with the key on or off
12-08-2020, 10:28 AM
Commercial Member
Here's a quick troubleshooting guide for the Equalizer control pad
