Old 09-28-2022, 05:26 AM   #1
Fireplace malfunction
On our way home from Elkhart after a pleasant day at Equalizer. Charles Butler is the Warranty manager there and he and his crew sent us on our way with a hydraulic system that is fine tuned. These are great people that represent a company that is proud of the products they created and, from my perspective, arenít satisfied until everything is right.
Now, here in the Madison/Pittsburg KOA. Itís a little rainy and chilly outside but a good evening for sitting beside the fireplace. The fireplace is not only a great source of heat but it does itís job quietly. Everything went well until I went to shut it down. The remote didnít work so I figured it was a bad battery. I went to the fireplace to shut it down with the controls on the unit. No luck. I had to shut off the circuit breaker at the foot of the bed. That shut it down. I reset the circuit breaker and the remote and controls on the unit worked.
Donít have confidence in a heat source with a potential problem while sleeping so used the furnace instead. Anyone had this problem and have a fix?
Not many hours on the unit.
Trappfarmer is offline   Reply With Quote
Old 09-28-2022, 06:17 AM   #2
GnKnTx's Avatar
Following…
GnKnTx is offline   Reply With Quote
Old 09-28-2022, 06:21 AM   #3
I didn’t experience that but did have an electrical fire in my electric fireplace with our 2021 MiniLite 2205S. Got it replaced under warranty but it does make you think twice.
I do find it unfortunate that once companies started to be run by accountants and virtually all manufacturing was shipped offshore quality and durability plummeted like a lawn dart.
2021 Rockwood Mini Lite 2205S
2011 Ford F-250 Super Duty 6.7L Diesel
WanderMore is offline   Reply With Quote
Old 09-28-2022, 06:39 AM   #4
Georgia Rally Coordinator
aceinspp's Avatar
Just curious does the fire place have on/off switch which to turn on first then press another to activate the fire place. Later RJD
2020 Shasta Phoenix SPF 27RKSS
2018 Dodge Ram 2500 6.4 3:73 gearing. Traded 2015 Chevy 2500 6.0, 4:10
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Days camped 2020 49 days camped 2021-74 2022-40 days
Old 09-28-2022, 06:54 AM   #5
Not on mine. It did plug into a circuit that was attached to a load sharing device. That device would shut off the fireplace if the microwave was being used. That being said, the fireplace switch and/or remote should definitely have shut off the fireplace.
As a kid, if something was made in Japan you often would question it’s quality. Over the years that sentiment changed as quality and durability improved.
Now that sentiment has shifted to China. I don’t see it changing like it did with Japan as China operates on a totally different political and social base. As long as the world continues to shop for the lowest price rather than the best quality things can’t change.
fireplace
