12-18-2016, 09:59 AM
Fireplace problem
A strange thing happened yesterday when I fired up the generator and fireplace in the Berk.
The fireplace started normally, but after a minute, the faux flames stopped, but the faux logs still looked like they were burning. The heat came out normally.
No more "flames"
Has anyone experienced this ?
Ken & Laurie
2022 Riverstone Legacy 39RKFB
2022 RAM 3500 Laramie Dually
12-18-2016, 10:14 AM
No...but I would look at replacing the light source which is usually a simple bulb replacement. Also, could be the rotating device which makes the flames stopped rotating.
2015 Rockwood A128S
2010 Rockwood 2604
2014 Ford F-250 CC SB 2WD
2008 Toyota Sequoia 2WD
12-18-2016, 11:39 AM
Did you know there's an adjustment for the Flames underneath the bottom panel?
Dan
2014 Berkshire 390RB-60
12-18-2016, 11:46 AM
No, I sure didn't. Thanks for that tip !
Ken & Laurie
12-19-2016, 11:15 AM
Happened to mine. Bulb(s) are out. Warranty replaced free of charge!
--Nathan
2016 38a
--Nathan
2016 38a
12-21-2016, 10:27 AM
Ken,
Did you find a fix for this?
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
12-21-2016, 11:30 AM
Dragonship Captain
I think he's in winter storage and is going to fix it in spring. As long as the heat part worked he wasn't too worried.
2020 RAM 3500 DRW Long Horn. In the hunt for a Palomino TC, formerly a 2017 Berkshire 38A: https://dragonship.blog/
12-21-2016, 01:27 PM
Originally Posted by BamaBob
Ken,
Bob: Like the reply right after yours (Oscarvan) said, It's not critical. It does heat okay, so I can exercise the generator. I did notice the flames do appear for a bit when I first turn it on, so it's not the bulb(s). Not sure if the cold weather is causing a problem with the mechanics of the roller. Next Monday, we're supposed to be in the upper 50's, So I will probably head out there with the tools. It may prove to be difficult, because I can't take the slide out. I have it covered.
Thanks for checking !!
Ken
Ken & Laurie
12-21-2016, 03:59 PM
Did you find the adjustment at the bottom?
Dan
12-21-2016, 04:34 PM
Just as confused as you
Ken
It could be the bulb. It could have a broken filament that makes contact until it gets hot. A matter of half a second or so.
12-21-2016, 07:57 PM
Waiting for 60 degrees on Monday
Ken & Laurie
12-26-2016, 12:27 PM
The warmer weather has hit !!
I pulled the fireplace out and took it into my basement at home. The rotating motor is fine. It appears to use two L.E.D.'s for a light source. They work, but are pretty dim.
They are soldered on to a small wafer circuit board. So I guess my question to anyone who had been in there, is how bright are your L.E.D.'s. ?
I'm guessing I'll end up going to the Mfgr's web site and seeking tech support on this one.
Thanks to all. Hope you had Merry and Blessed Christmas !!!!
Ken
Ken & Laurie
12-26-2016, 05:22 PM
Ken
You might want to use this for your fire...............
Hank
Gale & Hank- 2012 Berkshire 390BH
12-28-2016, 11:43 AM
Dragonship Captain
Oh, you so funny!
12-28-2016, 02:18 PM
Just got off the phone with the folks at DC Dimplex. They say it's either the controller board or LEDs. Even though it is out of warranty, they are going to send me both just to make sure, at no charge !!
Another good company !!
Ken & Laurie
