If you are having 'city water' draining out of your fresh water tank, then your water pump check valve has a small leak back flow and is not hold the city pressure back. Do you have a pressure reducer on the city water hose connection? If not... get one on there as the water pressure varies from Campground to campground. Also turn the 'city water' off and run the fresh water tank water pump a minute or two to try to dislodge the debris that is at the the check valve. If the leak/drip still continues, when time allows you may have to take the water pump apart and clean the check valve area. If you do not have the time to clean out the check valve at this time, shut the city water off and just use the fresh water tank until you have time to clean the debris out. This is also a lesson to shut the city water off when gone or a sleep as too much pressure on your lines could blow out a line or blow out your fresh water tank.
imo.
Brother Les
