Old 01-01-2023, 04:48 PM   #1
34B
Freshwater Tank drain
I am looking for the freshwater tank drain on a 2022 Berkshire 34B. All I found is a black valve on the passenger side next to the tank that is blocked by a panel. It doesn't drain any water. Any suggestions?
Thank you
34B is offline   Reply With Quote
Old 01-01-2023, 06:12 PM   #2
Hi,
I have a 2020 34QS which should be similar. On mine the freshwater drain can be accessed in the plumbing bay, on the left behind a panel. Reach in and pull the handle to drain the tank.
Good luck.
Jwleslie
jwleslie is offline   Reply With Quote
Old 01-01-2023, 11:08 PM   #3
34B
Fresh Water tank
Got it
Thank you:
Old 01-08-2023, 05:58 PM   #4
34B
Any suggestions how to sanitize the fresh water tank on 2022 34B?
Old 01-08-2023, 06:15 PM   #5
Top right of this page, above Welcome 34B
Type the word Sanitize in the search box, be sure FRF is highlighted in blue.
Happy reading.
2022 Rockwood 2511S
2018 F150 3.5 Crew Cab
Max Tow Package
Husky CenterLine WDH
GolfingDave is offline   Reply With Quote
Old 01-09-2023, 02:50 PM   #6
Welcome to the Forum, R34B.
I've written an extensive manual for my 2025 Berk 34QS, linked from my signature below. It discusses draining the freshwater tank (for light freezes and hard freezes), and it discusses authoritative links to sanitizing the tank and chlorinating questionable water supplies.
You'll probably find other useful material there, since it has a table of contents, hyperlinks and references to other material.
–cheers, Gordon
Gordon Sick, Calgary
2015 Berkshire 34QS
The Manual I wrote for our 34QS:
https://www.forestriverforums.com/fo...ml#post2579202
Toad: 2019 Ford Ranger XLT 4x4; Formerly: 2005 Acura EL (aka Honda Civic)
gordonsick is offline   Reply With Quote
Old 04-05-2023, 10:57 AM   #7
Same question but on a 2022 XL 38A?
ralpht52 is offline   Reply With Quote
Old 04-05-2023, 12:17 PM   #8
The OP posed the question of where to find the drain for the freshwater tank. The thread goes on to pose several related questions and answers.
So, when you say "Same Question", you'll get a more helpful answer if you repeat the question that is on your mind, for clarification.
–Gordon
2015 Berkshire 34QS
Old 04-05-2023, 12:38 PM   #9
Commercial Member
Here are some pics where the fresh water valve is located on the Berkshire.
Name:	FRESH WATER DRAIN_ (1).jpg
ID:	285507   Click image for larger version
Name:	location of fresh water valve (1).jpg
Lincman983 is offline   Reply With Quote
Old 04-10-2023, 09:35 AM   #10
Diesel Rep West Coast
Eric B FR Diesel is offline   Reply With Quote
drain, tank, water, water tank
