Old 09-18-2020, 07:23 PM   #1
Gauges
Hi everyone, I have a 2008 Forest River Berkshire 390QS. This morning started up the MH. All of my instrument panel but 2 would not work. The only 2 that works were Air Tank 1 and 2. everything else would not come up. No Diesel, battery, RPM,
The indicator light and busser that's ON, is Ref. LOW AIR PRESSURE INDICATOR.
Both tank 1 and 2 are showing 125 pressure. They are the only 2 that work.
Any help would be great.
Bill
bcullifer is offline   Reply With Quote
Old 09-18-2020, 08:24 PM   #2
I’d sure look at a main fuse and the ground(s). Did you try the auxiliary switch as well?
2016 Berkshire XL 40A towing 2020 Jeep Wrangler unlimited.
Prior to this Jayco fifth wheel: 24' Eagle, 30'Designer, and 40' Jayco pinnacle.
Igave is offline   Reply With Quote
Old 09-18-2020, 08:56 PM   #3
ernest917's Avatar
Bill....
Have you had the main wiring cluster in your dash replaced???? It was a recall item!!!
They replaced mine and it solved all my similar issues... I can't remember it they replaced white with black or vice versa....
If you haven't had yours replaced, then the replacement wires will be the opposite of what you currently have....
ernest917 is online now   Reply With Quote
Old 09-18-2020, 09:54 PM   #4
Originally Posted by ernest917 View Post
Bill....
Hi Ernest,
Do you know were I can find the recall. check FR couldn't find it
Bill
Old 09-18-2020, 10:00 PM   #5
ernest917's Avatar
Call your local Freightliner Service Center..... They should be able to look up the recall for you and then do the work...
I had your same issues on a trip we took to Maine a couple years ago and the Freightliner center there took care of it for me... They removed the entire wiring harness and replaced it.....
Old 09-18-2020, 10:02 PM   #6
ernest917's Avatar
I can promise you they need to replace yours.....
Old 09-18-2020, 10:04 PM   #7
Originally Posted by Igave View Post
Id sure look at a main fuse and the ground(s). Did you try the auxiliary switch as well?
Wouldn't know were to look.
Bill
Old 09-19-2020, 07:44 AM   #8
Hello Ernest, called about recall, they could not find a recall number, would you have that number so I could give it to them. Thanks for any help
Bill
Old 09-19-2020, 08:24 PM   #9
Had this issue in June...
Happened to me exactly as stated. Took it in and Freightliner checked to see if it was a recall item with no success. So, about $2,200 later we were back on the road.
Phil & Kathi
USAF/USAF Civil Service Retired; 2013 Forest River Berkshire 390FL, 2011 Equinox, TireTracker
KPfulltimers is offline   Reply With Quote
Old 09-19-2020, 08:36 PM   #10
found out how to fix the problem.
I did a hard reset of the coach batteries and it reset all the gauges. SUPER Happy
Old 09-20-2020, 12:37 AM   #11
ernest917's Avatar
Thats GREAT!!!!
