Generator will not shut off automatically.
I did have my generator remote set so it would start at a certain voltage, run for a certain length of time an then would turn itself off.
Now the generator will not turn off automatically. Did I change the programming somehow, not knowingly? If so what setting did I screw up?
To make matters worse is the manual generator on_off switch in my dash will only turn the generator on! It will not shut the generator off! I have to go outside and push the on_off switch located on the generator.
I thought there was suppose to be a way I should be able to turn off the generator from the remote, but I don't seem to find it.
Or did the switch go bad, thus making the remote unable to turn off the generator automatically? I'm traveling so getting a new switch is not going to be easy.
Thanks, Ernie
2014 Berkshire 400QL; sometimes towing 2018 Silverado and other times
towing my 20' Aluma trailer with a vehicle on it.
