Old 10-29-2013, 06:14 AM   #41
EJM4's Avatar
Originally Posted by Phil57 View Post
I'm sure you have tried all the fixes but just checking. Do you have a shower head that mixes air with the water. Not sure what brand is best. That did help with ours. Also do you have a pressure regulator. I also found that the water filter was very restrictive I went without for awhile and it made a very positive change in how the water heater worked. Now I use the biggest micron filter I can find. My plan is to get a large filter out side the MH. I think that will improve the water heater results.
I too have removed the water filter cartridge.
Phil - What filter are you using? Lowes / Home Depot?
Earl
2013 Berkshire 390BH / 360hp
EJM4 is offline   Reply With Quote
Old 10-29-2013, 07:14 AM   #42
frankatp's Avatar
Thanks for the info Guys. I will try removing the filter from in line and see if that helps the situation. I don't know if our shower head mixes air or not. It is the one that came with the coach. Will check that out today and let you know.
frankatp is offline   Reply With Quote
Old 10-29-2013, 07:45 AM   #43
Batts-toy's Avatar
Originally Posted by frankatp View Post
We had ours replaced with the newer model and find it still takes two people to get the temp just right for a shower. We have to turn the dial all the way to the right to get the water hot enough for dishes, then turn it back for showers. I am not sure that tankless is good for an RV. There is too much variation in water pressure at campgrounds to be effective. I will say that it is better than the first generation but it still sucks.
I'm not following this, how come you don't leave the setting at dish water hot and use the cold and hot water handles in the shower to get he temperature mix you want?
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 10-29-2013, 07:53 AM   #44
EJM4's Avatar
That is how we operate the system.
Earl
Old 10-29-2013, 08:04 AM   #45
frankatp's Avatar
I guess we were trying to follow the factory directions by not using the cold water. Don't really have another answer. Will try that for sure our next trip.
Old 10-29-2013, 08:06 AM   #46
EJM4's Avatar
If you have the Gen 2, check the instructions from Girard and it will mention about mixing cold water in to cool the water if needed.
Earl
Old 10-29-2013, 08:50 AM   #47
Thanks for posting this. We use the cold to mix also.
Old 10-29-2013, 08:52 AM   #48
I too have removed the water filter cartridge. Phil - What filter are you using? Lowes / Home Depot?
I use Lowes I think 40 micron.
Old 10-29-2013, 08:54 AM   #49
The stock shower head does not mix the air(at least our doesn't ) we got or new on from Garrard so not sure the brand. I have seen them at Camping World.
Old 10-29-2013, 10:05 AM   #50
tmmar's Avatar
I believe the shower head you are thinking about is the Oxygenics shower head. We have had one for a while now and really like it.
Tom and Margaret
2014 Berkshire 390bh-60
Old 10-29-2013, 10:10 AM   #51
Thanks Tom that's the one I was referring to also. Have we seen pictures of your new MH?
Old 10-29-2013, 10:36 AM   #52
EJM4's Avatar
Show that new coach off !
Earl
Old 10-29-2013, 11:22 AM   #53
I am getting rid of my tankless for several reasons. First, I don't like real hot showers and to get to a temp I am comfortable with I have the hot on full and add cold. As we boondock a lot this is a waste of fresh water. Also, the tankless units use an induced draft blower and that takes battery power, much more than the circuitry of a standard type of rv water heated. Yes it uses more propane but we can turn it in, bring the water up to temp and shut it off. The water in the insulated tank stay hot for a long time.
As alway, just my opinion.
Filthy Beast is offline   Reply With Quote
Old 10-29-2013, 12:47 PM   #54
tmmar's Avatar
Due to popular demand (LOL!)
OK- Lets see if this works.
http://www.shutterfly.com/lightbox/v...944dfefaeb216b
Tom and Margaret
Old 10-29-2013, 01:40 PM   #55
jevanb's Avatar
Until I run out of propane or the grey water tank fills up if we are not at a park.
x2 after I got rid of the bugs (no help from the dealer, under warrentee) and talked to girard and fixed it myself, it is wonderful now
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 10-29-2013, 06:33 PM   #56
Tom I can't get that link to work.
Old 10-29-2013, 06:38 PM   #57
Ford Idaho's Avatar
Works fine for me.
Old 10-29-2013, 07:07 PM   #58
Batts-toy's Avatar
The link worked for me but it wanted me to register as a member. No Thanks
heater, replacement, tank, water, water heater
